Corvette Performance
C5 | Z06 | C6 | ZR1 | C7
01-02 zo6
Old Mar 24, 2007 | 12:29 PM
Kurtomac's Avatar
Default 01-02 zo6
i hear about all the TM bullcrap problems that people are having with the new z06 is it the same with the 01 and 02's
also any reason i should steer away from the 01 z06 being the first year available and go with the 02?
Old Mar 24, 2007 | 12:32 PM
Kurtomac's Avatar
well i just seen the sticky thread at the top....woops...anyway still wanna know about the TM and any common probs with the z06's in general
Old Mar 24, 2007 | 01:36 PM
jbuerke142's Avatar
as far as i know probs with 02-04 are minimal... but yes, as a rule avoid 01's. some have been fine though.
Old Mar 24, 2007 | 02:34 PM
blown4.6's Avatar
All of the torque management problems can be solved by a tune.
Old Mar 25, 2007 | 12:53 AM
jeffyvette's Avatar
Default only other reason
The only othe thing I can think of is that 01's were rated at 385hp and 02's on are 405hp.
Jeffy'
Old Mar 25, 2007 | 02:32 AM
O2Thief's Avatar
Many 01's out there with no problems. Just research your candidates. Regarding the 01's, nothing a cam and exhaust change wouldn't solve to surpass the 02+
Old Mar 25, 2007 | 04:57 PM
JudgeGuns's Avatar
'01 is a great vette. i got an 02 because the cam has more lift (.250 more) and the cats are bigger.
the oil usage thing was in less than 20 percent of the 'o1's so it is unlikely you get one. most were fixed too, plus it doesn't hurt performance any. just have to add a quart now and then. unless if you don't get close to redline a lot..then they don't burn anymore than any other z06
i drove a '01 Z06 with expensive custom exhaust and intake and performance tune and it was fricken fast! tad more than my stock 02 z06
miles were 50k+ otherwise i would have bought it. try to get one from the original owner, makes huge difference
G/L
Old Mar 25, 2007 | 04:59 PM
JudgeGuns's Avatar
z06= manual
Old Mar 25, 2007 | 08:45 PM
Kurtomac's Avatar
Originally Posted by JudgeGuns
z06= manual
TM is also an issue in manual cars
Old Mar 25, 2007 | 09:42 PM
AllShowNoGo's Avatar
The only problem i have with my 02 Z06 is i cant keep my foot out of the throttle.
Old Mar 25, 2007 | 10:12 PM
~JOSHUA's Avatar
I drove an '02 Zo6 (48k miles) on Friday, and an '01 Zo6 (73k miles) on Saturday.
Although both were bone stock.. in my opinion the '01 felt a tad faster.
Old Mar 25, 2007 | 11:36 PM
JudgeGuns's Avatar
Default tm
sorry im a noob ... but how is torque management addressed in a z06?
is there actually a value you change in the computer?
im tryin to learn about tuning and get the computer and wide band and do mine...eventually
Old Mar 25, 2007 | 11:44 PM
cantdrv65's Avatar
Post
I LOVE my 01Z! I never had a torque management issue....
Old Mar 28, 2007 | 03:44 AM
JudgeGuns's Avatar
As I said in an earlier post, the algorithm is in the PCM, but a car with a manual tranny CANNOT invoke it.
From the Service Manual ..... page 6-1034 (PCM Description)
subsection: Torque Management
"The PCM monitors the torque converter status, the transmission gear ratio, and the extended brake switch input in order to determine if torque reduction is required."
Hmmmm ... let's see ... on a car with a manual tranny there is NO torque converter, and the PCM has NO idea what gear is selected in the gearbox. Kinda hard to do torque management when you're missing two critical inputs to the algorithm.
QUOTE:
Further on the manual lists examples of times where TM would be experienced ... here are two that clearly indicate it applies to automatics ...
* During transmission upshifts and downshifts
* When the driver is performing harsh or abusive manuevers, such as shifting into gear at high throttle angles or shifting the transmission from Reverse to Drive to create a rocking motion
None of the examples are for a manual gearbox since, taking the above, the PCM has no idea when you're up or down shifting, and I have yet to find a DRIVE position on my shift **** ....
