Are there any 18 gauge headers for C6?
Also I feel that 409 stainless steel is the right way to go. Plain steel ceramic coated headers could possible rust and corrode in time. Particularly if porting and clean up is required or there are any installation scratches. The 409 and 304 are not going to rust. 409 can exhibit some very light rusting but certainly nothing that will cause a problem. 409 cuts much easier than 304 and lends itself much better for porting and cleanup. I've used many brands of headers in past 20 years and all required some porting and/or cleanup before installation.
Don't care to go with 1 7/8 either. They have to weigh more and take up more room. Although they flow more my engine is virtually stock so the larger 1 7/8" is not needed.
Don't know much about header sizes, so I'll wait for someone who knows something to chime in. Good luck on your purchases, and when you decide what's the best combo (thickness vs diameter vs wt) let us know.
Yep, looks like the mods are fixing to start. I sure hope I don't get too carried away like I did with the Camaro.
Do you think our engines will benefit from 1 7/8 vs. 1 3/4? If a stock heads/cam engine will flow just as good with 1 3/4 I would prefer them. They should provide more clearance and possibly easy of installation. Are your Kooks 304 or 409 stainless? With 1 7/8 the gauge doesn't make much difference concerning flow but could add weight if a very heavy gauge. Aparently yours are close to factory weight.
I have been unable to find out much about headers. May have to call some of the manufactuers to find out more. Without visual inspection don't know how much porting would be required. That's a real benefit of 409.
I haven't made it back out to the track since the 12.20, been busy with work & coaching my son's t-ball team. I've got some "parts headed my way, so I'll be out soon.
They do need some minor porting. The porting needed won't produce any more hp on my engine but I like smooth passages. Where the cones are welded into the collector the weld spills over. I have a long carbide burr that I use to clean this weld.
What do you have coming? Supercharger?
I'm not much of a supercharger fan, even though the results on the C6's are unbelievable! I've always leaned toward nitrous when it comes to power adders, it's light & immediate. I'll keep you posted on my new upgrades. Shhhhhhhh!
