Corvette Performance
C5 | Z06 | C6 | ZR1 | C7
Nitto 305/45/18
Old May 15, 2007 | 02:04 PM
ROJASS1's Avatar
Default Nitto 305/45/18
I have a buddy of mine that bought some Nitto Drag Radials which are 305/45/18's but he decided to go with a BFG 315/30/18's instead so he is going to sell the Nitto's. Will the Nitto 305/45/18's fit on my 01 Z06 Vette? The tires are brand new and he is willing to give me a good price on them but I told him that I needed to make sure that they fit my car first. I appreciate any information someone can give me on this.
Old May 15, 2007 | 03:12 PM
dixonk's Avatar
As long as the rim is 10 to 10.5 inches wide no problem. Any less then that and they will fit but they will bulge really bad. I have 10.5 inch rims and they slightly bulge.
Old May 15, 2007 | 04:25 PM
SAM98WS6's Avatar
I put them on this weekend...10.5" rim...like a stock Z06...they work great.
Old May 15, 2007 | 06:52 PM
50_Dave's Avatar
Im putting 305/35/18 drag radials this friday
shouldnt be a problem
Old May 15, 2007 | 11:39 PM
02ZOh6's Avatar
The 45's were meant for Lightnings,etc. (taller profile) and the 35's for cars.
Old May 16, 2007 | 01:10 PM
ROJASS1's Avatar
Default 305/45/18
Thanks for the information. So the 45 series is more for trucks then? So would I be better off using the 35 series? Thanks again.
Old May 16, 2007 | 02:18 PM
02ZOh6's Avatar
That's correct. Try to go with the 35's if possible.
Old May 16, 2007 | 02:27 PM
ROJASS1's Avatar
Thanks for the informtion. I will go ahead and order the 35 series instead.
Old May 16, 2007 | 02:52 PM
dixonk's Avatar
The 45's have a better sidewall though, correct?
Old May 16, 2007 | 03:21 PM
Pro Stock John's Avatar
LS1Tech Co-Founder
Community Influencer
The Lightning ones are 28 inches tall right?
Old May 16, 2007 | 05:02 PM
ROJASS1's Avatar
Do you have drag radials on your car? If you do what size are you running with?
Old May 16, 2007 | 05:05 PM
ROJASS1's Avatar
So did you put the 305/45/18's on your car or did you go with a 305/35/18?
Old May 16, 2007 | 11:22 PM
dixonk's Avatar
I am running Nitto 555R Extreme II's 305/35/18. The 45's are not available here. Just thought that having a taller sidewall is more beneficial for drag racing if that fits and is available.
Old May 17, 2007 | 12:17 AM
02ZOh6's Avatar
Definately go with the 35's if possible. Yes, the taller sidewall may allow for more flex. But, it may also look like a 4X4.
Old May 17, 2007 | 02:17 AM
dixonk's Avatar
True on that one.
Old May 17, 2007 | 03:05 AM
LKGRenegade22's Avatar
The 45 series look really funny under the back of a vette. Go with the 35 series or you will regret it. It will look like you have the rear end of your car jacked up with 305/45/18's. They were designed for the lightning trucks.
Old May 22, 2007 | 04:20 PM
LuvmyC5's Avatar
I think that the 45's would also throw off the speedometer and even possibly some other computer readings. I just got the 35's for my car but haven't had chance to try them out yet!
Old May 23, 2007 | 08:26 AM
YankeeVert.'s Avatar
The taller tire 28" vs 26" will give you the equivilant of a lower numerical gear (3.42 becomes 3.17) and will hurt your performance much more than the taller sidewall helps. GO WITH THE 35!
