Corvette Performance
C5 | Z06 | C6 | ZR1 | C7
best gear for C5 on the bottle
Old Jun 11, 2007 | 09:09 PM
02402RAMAIR's Avatar
Default best gear for C5 on the bottle
What is the best gear for my C5 6 speed stroker on a 250 shot?
I have been told that the stock 3.42 gear would work best on the bottle.
This will be used on 1000ft and 1/4 mile drag.
any help would be appreciated
Old Jun 11, 2007 | 09:22 PM
99FRC's Avatar
I'm only spraying 100 but the 3:42 feels just right!!! The 1-2 and 2-3 shifts come pretty quick when you're spraying.
99 FRC
Old Jun 12, 2007 | 07:28 AM
Dragman's Avatar
I agree!
Old Jun 12, 2007 | 10:03 AM
Z O SICK's Avatar
I'm running the stock gears with my 402 + 150 shot set up. No problems here!
Old Jun 12, 2007 | 01:54 PM
will82's Avatar
From: Somewhere Between Mild Insanity and Complete Psychosis
Yep. No need to change.
Old Jun 12, 2007 | 02:34 PM
I am replacing my rear diff so right now it won't cost any more to change gears.
Thanks for the info guys. I am going to stay with the 3.42
Old Jun 13, 2007 | 09:09 PM
I bought a NEW Z06 3.42 rear diff and replaced the long shaft with a 300mm shaft. GM has a 12/12 warranty on there diffs.
Thanks for all the input and help on this issue guys.
Problem is solved for now.
Old Jun 13, 2007 | 09:47 PM
Z ROADSTER's Avatar
Wouldn't a Z06 Transmission be advantageous due to the very high low gear ratio . It would seem so with the closer ratios keeping the engine right in the middle of its power band. I know the RPM's drop very little between gear changes & I've heard that the Z06 transmissions are very heavy duty and robust & have been compared to the now famous M22 rock crusher .
