Corvette Performance
C5 | Z06 | C6 | ZR1 | C7
C5 top speed
Old Jun 27, 2007 | 01:28 AM
~JOSHUA's Avatar
Originally Posted by Wide Open
I have been to 173 and hit the rev limiter with my tach indicating 6300. The engine was pulling hard enough to go several hundred rpm more but there is no way it would get to 200 stock, or with the stock gearing for that matter. Speed was verified by viewing the max speed data on my GPS.
It makes sense that the factory's system can load up at high speeds, but the one thing that sounded odd was you mentioned "6,300rpm"
My redline is about 6,600 rpm... and soon with a cam/springs the rev limit will be a lil' higher..
Old Jun 27, 2007 | 06:59 AM
SilveradoSS500's Avatar
Yo! You got tricked! Get over it.....I will post my CTSV video hitting 200mph, if i have to....
Old Jun 27, 2007 | 07:01 AM
http://video.ls1tech.com/video/0e009...5a0085639d.htm
Give it a bit
Old Jun 27, 2007 | 10:49 AM
98 Formula's Avatar
In the german Corvette-Forum the do many tests with GPS. C5 from 177-183 mph stock and C5Z06 173 mph. The german A4 have all 3.15 gears so they most time faster in topspeed than the M6.
Old Jun 27, 2007 | 12:59 PM
miami993c297's Avatar
In my ZO6 with stock gear box ratio / 3:42 rear end and stock tires I did 187mph @ 7025rpm Fifth gear HPTuner recorded and GPS confirmed...
Here is a video @ 185 mph:
http://www.youtube.com/watch?v=pYhRh7XZ8Gw
Christian
