How to 99-02 PCM into 97-97 vette with pics!
I was just curious, if you have the motor out would it work to just change the engine harness and computer with a newer 99. I have a 98 corvette and I plan on buying a 99 harness and computer out of a TA. Will this work for me?
Cool thanks for the reply, So the 99 TA comp will work just not the harness. But being I have hp tuners I will have to buy EFI live correct to make all the program changes. I do thank you for the help and have plenty of exp repinning plugs I was an AFIN troop on the C-17 till I changed to LM just have to be so tedious on a multi pin plug like that.
Eurospec, i am attempting a similar swap like yours in my 98 camaro a4 to a 02 ecm. i have the ecm diagram and have figured out where most of the pins are with the exception of some wires are not available from one to the other. Did you have any extra pins that were not used or not enough (example, i dont need egr, but there are alot more 5v references needed on the 02 that are not on the 98 wiring harness). I'm confused! Thanks in advance for any info, Carlos R.
If your going big cam, nitrous, forced induction do the swap you wont regret it
all i have is exactly what is in my sig, but i plan on porting the heads, and adding a 100 shot of nitrous... im sorry i know you have prolly been asked this a thousand times, or that there are hundreds of threads on it but since you seem to be the guy that knows his stuff on this subject, what all is better between the two??? i thought you said something about a/f tables or spark tables... is an updated pcm just easier to tune or could it be done with the 98? I hope it doesnt seem like i asked the same question twice, im just really interested...
#32
![Happy](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_stretch.gif)
This is possible with EFI Lives custom operating system number 5, which is only avaliable for the 99-02 PCM
#34
Hey, I KNOW YOU...I saw that red vette on a trailer in front of me last weekend..heading to Gainesville !! It actually runs good with that new computer !! BlueCajun, Sportside and me heading back, Saturday the 08th if you can go....10:00 am gates open again. What ya think Bro ?
Pit (hit the brakes) man
#35
Dec 8, i may be able to come depending on if we have cars to tune that day, but my car defenetly wont be there, i wish i had an auto....
