Corvette Performance
C5 | Z06 | C6 | ZR1 | C7
supercharger question help
Old Aug 4, 2007 | 11:11 AM
SVT BAIT's Avatar
Default supercharger question help
i have a p1sc on a stock a stock ls1 motor ima get a forged motor and want to upgrade to a D1 can i just replace the headunit or do i have to replace the brackets and everything else?
Old Aug 4, 2007 | 11:57 AM
MagiC5's Avatar
For a faster answer... i'd probably sneek over to Corvetteforums.com and check out the FI section. I bet a search there would find you an answer.
Old Aug 4, 2007 | 02:51 PM
Quik Z06's Avatar
I believe its just the head unit. Ive heard you can send in your P1 and they can make a D1 out of it, so if thats true your current brackets will works.
Old Aug 6, 2007 | 02:11 PM
3tenths's Avatar
bracket is the same for both, the d and p head units are the same, just interal differences.
you may want to look into changing the brackets for other reasons though (belt slip, etc.) depending on what brackets you curently have.
Old Aug 6, 2007 | 02:27 PM
SVT BAIT's Avatar
well i have the A&A p1sc
Old Aug 6, 2007 | 02:51 PM
ls1290's Avatar
Dumb Ass Vette Moderator
Yes you can swap the P1 for a D1 with all of Andy brackets. You can even fit a F1-R on it
Keith
Old Aug 6, 2007 | 05:33 PM
MagiC5's Avatar
seems i was wrong... great answers
Old Aug 6, 2007 | 08:41 PM
SVT BAIT's Avatar
kool thanks for the info guys !
Old Aug 7, 2007 | 03:43 PM
mdhmi's Avatar
Yes, you can upgrade the head-unit from a P-1SC to a D-1SC for a little north of $1,000. The problem is that if you're going forged and intend on running a smaller pulley and making some real power you'll probably want to step up to an 8 Rib belt assembly and possibly more efficient intercoolers, depending on what you already have.
Old Aug 7, 2007 | 05:13 PM
V-seriesTech's Avatar
I take ityour speaking about the stock TWIN intercoolers offered by procharger.
I have logged my IAT's, and I gotta say, I have no need to change them at the moment. I understand, more boost, more heat. Which brings me to the question, at what boost levels, are the TWINS efficent up to?
Cause, really, I was, dead set on doing a single front mount(which I will no matter what down the road) right away but, after logging with my predator,..these things were pretty good.
Thanks, J
Old Aug 7, 2007 | 08:09 PM
mdhmi's Avatar
I can't answer your IC question as I started with a FMIC. I just mention it as something to consider. I'd be more interested in the 8 rib upgrade, provided you don't already have one.
Old Aug 7, 2007 | 10:07 PM
SVT BAIT's Avatar
kool, yea i have the FMIC
Old Aug 9, 2007 | 04:56 PM
pakisho's Avatar
My twin intercoolers were useless with a 4.25 pulled on a D1, stock heads/cam, forged bottom end. They heatsoaked very quickly and you could feel the car fall on its face in fourth gear after running it up a few times.
You need a front mount with a good amount of distance between the IC and the Rad, and a halltec nosepiece. And you need an 8 rib if youre going to push it.
