Corvette Performance
C5 | Z06 | C6 | ZR1 | C7
Abs Active Handling !!?!!
Old Aug 9, 2007 | 12:01 PM
MagiC5's Avatar
Originally Posted by NOS USER
Magi : My EBCM located in the rear of the car near the trans oilpan ?!! is it right ? or only my car have the EBCM there?!
It should be upfront... i can't think of why yours would be located in the back. Check the link posted directly above mine and ready through there. Bill is good people.
It could just be a grounding issue or as nmp stated it could besomething werid like your wheels sensor, but the fact that you lost the use of your brakes probably means it's something more than just one sensor. I still think based off the commmon problem with the EBCM, i'm going to guess the problem is either the the EBCM it's self or a ground leading to it which would also mess up the EBCM. Check out the other thread and see what you get.. But ya.. it should be located in the front.
Old Aug 9, 2007 | 02:22 PM
trinijoee's Avatar
97 C5's & early 98's have the unit in the rear.
Old Aug 9, 2007 | 03:44 PM
NOS USER's Avatar
Thanks guys
NOS USER's Avatar
Thanks guys
Old Aug 9, 2007 | 07:30 PM
dust6928's Avatar
hs anyone inspected one of these repaired units to see what was done to them? If he can get these things repaired in one day their must not be that much to it.
Old Aug 10, 2007 | 04:46 AM
Quik Z06's Avatar
Im sure there isnt much to it, but I never looked into it. For $150-200, I didnt care what they did as long as it worked. GM wants like $15-1700 for the damn part.
Old Aug 10, 2007 | 08:09 AM
MagiC5's Avatar
Thank you.
Sorry for the confusion NOS.
as for how they fix it in a day....
I'll guess it' like a handful of other GM electronic board problems.. Probably bad solder.. 5 min job at best for the experianced... Just a guess....
