11.4's@124.48mph once again SHOOT ME!!!w/video
Originally Posted by CobraB8_ZO6
because i cant find a tb to fit my zo6 cause it is electronically driven and all the aftermarket tb are cable driven. where did you get a 90mm ls2 tb from?
h777----how you do you know the DA for this past wednesday??? Not doubting you but want to know how to figure that out. I like to write down Tire pressures, air temp, lanch rpm, shift rpm etc etc on my slips and keep them categorized to see how the cars doing and what works. Does anyone have a link or something that you plug info into to calculate the DA???
Originally Posted by Zturd
Go to digitalcorvette.com and look in their c5 classifieds theres one in there really freaking cheap with the wire adapter for $150.00 or covetteforums.com and you'll find plenty. good luck
there are many sites that keep records of the past weather in most locations, after checking the past weather go to this site for a D/A Calculator, also cecil county is at 320 ft you will need that number when you check the D/A try this site, http://wahiduddin.net/calc/calc_da.htm
on wednesday the D/A was + 1700 at 7 pm
heres a site that you can check past weather
http://www.wunderground.com/weathers...y=29&year=2007
