Corvette Performance
C5 | Z06 | C6 | ZR1 | C7
preventing wheel hop
Old Sep 9, 2007 | 07:57 PM
bzettler83's Avatar
Default preventing wheel hop
The title says it all... I have a2003 C5 Z06 is there anything I can do to reduce or elim wheel hop. Dont get me wrong its not bad if and when it happens but I hear it can lead to breaking the rear which I dont want to do... On my T/a I added LCA's , T/A, PHB, this and that but the vettes are new to me , what can I upgrade thats not too expensive.
Old Sep 9, 2007 | 08:02 PM
2MuchRiceMakesMeSick's Avatar
Nitto DRs helped mine alot.
Also learning how to launch helps alot too.
I would recommend getting a DTE brace very soon.
Old Sep 10, 2007 | 12:04 AM
Robert56's Avatar
ET Streets for dragging.
Robert
Old Sep 10, 2007 | 12:25 AM
mdhmi's Avatar
Get better tires. A DTE differential strut brace certainly doesn't hurt to have. That won't prevent wheel hop, but it can help limit drive line destruction caused by wheel hop.
Old Sep 10, 2007 | 11:06 AM
Fastbird93's Avatar
From what I've seen, upgrading to a stiffer shock will make a lot of improvement too.
Old Sep 10, 2007 | 07:59 PM
VortechC5's Avatar
Good luck getting rid of the hop. I have had different shocks, tires, and wheels on mine and I have never gotten rid of the hop. It would even hop when I was running BFG drag radials.
Old Sep 10, 2007 | 09:14 PM
Emuffinman's Avatar
I run 345 DR with 25 LBS. with Bilstein Sport shocks with no problems. Running 30 lbs. I get hop. Before the shocks and DR, I broke a drum in a RPM transmission with a little gas and a bump on the interstate. A DTE would help.
Old Sep 10, 2007 | 09:24 PM
DarkC5's Avatar
I noticed a lot of wheel hop when I had run flats...so i moved to a regular street tire and that helped a bit. Then I moved to a BFG drg radial and all my problems were solved.
Old Sep 10, 2007 | 10:37 PM
Fastbird93's Avatar
I'll find out about my setup on Wednesday. Stock rear, no DTE brace, 305/35-18 Nitto DR's, lowered, and Bilstein shocks.
Old Sep 10, 2007 | 11:14 PM
SilveradoSS500's Avatar
DR's made a big difference....
Old Sep 10, 2007 | 11:43 PM
bzettler83's Avatar
I currently run 315/30/18 Falken TR 615's
Old Sep 11, 2007 | 06:02 PM
GTFORMULA's Avatar
I never got any wheel hope on 28x10 Hoosier slicks only broken trans main shafts.
Old Sep 11, 2007 | 09:07 PM
Robert56's Avatar
Looks as though you don't have a dte strut brace? The brace will stop this for the most part. Your lucky, most who break the trans shaft also break the trans case, and differentle case, and big bucks for all.
Robert
Old Sep 12, 2007 | 05:40 AM
GTFORMULA's Avatar
I had the DTE brace, both shafts, and good clutch. Broke the main shaft where it goes into the pinion gear. Twisted it in two with my cam only 03 Z06. It reminded me why`I did a solid axle in my 99 FRC.
