Beware of firefightergib!!!
Does anybody have any opinions or suggestions on what I should do about this?
That sucks. I'd buy a 50 cal, magnesium round..and setup somewhere off in a distance.
Sorry about your loss.
What size turbo?...any pictures of the incomplete kit?
dude its like this, i told you i had some problem with the oiling system that it would come out the exhuast and it would be the pump that i thought it was the pump. The turbo WORKS perfect other than it leaking oil. Let me say that in a different way, it worked fine when i owned it and you can not say i did not tell you about the oil leaking out of the turbo. As for the piping i did not take it all off, it was actually a performance shop in Cleveland, AL I made a call and they found the piping so i will be more than glad to send this to you, no charge to you. As far as getting your money back I did not twist your arm off when you came and picked it up you saw the oil on the turbo, you didnt have to buy it. Just let me know what you want me to do on the piping. josh
firefightergib,
If there are extra plumbing pieces that where not sent and should have been, send them out. As far as the oiling issue, it seems that it was disclosed. If the pipes are sent out, I will consider the matter closed.
01c5,
It seems like you where expecting a new or new near kit for $1200. Considering new kits go for $5000+, you should have investigated this more and lowered your expectations. There is the saying "You get what you pay for".
I will keep this thread open for now until the extra pipes arrive.
Keith
Yeah you told me it was leaking oil because you had the wrong oil pump you did not tell me that the turbo was completely fucked up. and that's why I bout it you said oil pump was to blame but everything else is ok. the shop said they could not repair it that all it basically was was a paperweight, so unless you can get me a new turbo or fix this one I would like my money back.
I bought a used Vortech off ebay. It spooled up a whopping 4 psi boost.
I had to have it rebuilt but I kinda knew that going in.
If you're unsatisfied, he has offered a refund. (perhaps you can work partial refund and have it rebuilt, you'll still be money ahead... and with a FRESH turbo.).
$1200 for a system is pretty dirt cheap. IMO
Seems to me that it all boils down to whether firefightergib wants to make things right, and from the lack of responses to your phone calls/emails, it seems he doesn't care. Not something I'd expect from a firefighter. I've always placed them high in moral standards and integrity.
Uh, I'd say the oil pump is working fine and you've got a turbo problem if oil is coming out of the turbo.
Sounds like o1c5 may be guilty of ignorance and gib guilty of taking advantage of it. I guess we'll see what happens...
Firefighter, do the right thing and give the man his money back.
A person can't sell something - saying it "works" - but leave out the part that says... "though it can't be used as-is, and would need some sorta repair before installation".
If a person said that, then the value of the item he's selling would drop like a rock.
A whole turbo kit for $1200 that normally goes for $5500+ says to me that there is something wrong with it. Everything that I have read and/or heard from indicates that Firefightergib said the turbo had problems and that it was leaking oil which he believed was the pump. If it turns out that it is the gaskets, then Firefightergib should give some type of refund to have the turbo fixed. IMO that is just the right thing to do. His lack of response indicates that he is not willing to do that.
This is all the danger of buying/selling used parts. Often one man's junk is another man's treasure and a good deal can be had. Sometimes a man's junk is just that, junk. One needs to have the knowledge to determine that.
Keith
