Corvette Performance
C5 | Z06 | C6 | ZR1 | C7
PCM guestion
Old Oct 17, 2007 | 09:51 PM
fastorgbird's Avatar
Default PCM guestion
I want to install a shift light in my Vette but I can not locate the pcm. The on in the floor board on passanger side is not the correct one. Were is the 80 pin pcm located? Help!!!
Old Oct 18, 2007 | 12:00 AM
03BlackWidow's Avatar
In the area below your battery. I think most remove the pass. side inner fender and access it that way
Old Oct 18, 2007 | 12:26 AM
DarkC5's Avatar
Take the battery out and the tray and you can see it clearly. But like the other response says....take out the inner wheel well and look at it from underneath, you can find it there very easily.
Old Oct 18, 2007 | 11:24 AM
Todd157k's Avatar
There's actually a small cover IN the fender well that comes off to access it. Not the whole fender well.
