Corvette Performance
C5 | Z06 | C6 | ZR1 | C7
Need Advice
Old Dec 8, 2007 | 10:59 AM
quicksilverz06's Avatar
Default Need Advice
Like most of u know alot of z06's have the problem of cluth sticking to the floor. my car is one of those. i replaced the slave and the master cylinder. my car worked fine for about two months but did it again.so then i replaced the master again and did the drill mod but still have the problem. i took it to a friend of mine and he told me it was probably cause i bought them at advance auto parts. he also said he had a similiar problem in his camaro and that he went to gm and bought the slave there. the brand of his master was mcloud or something like that. its aroung 420 for that master i wanna what u guys think cause i dont want to buy it and still have the problem. oh i forgot to mention i clean the brake fluid once a week, i use dot4. thanx in advance
Old Dec 9, 2007 | 07:56 PM
DocT's Avatar
Bump for ya, I'd like to hear some input here as well.
RT
Old Dec 9, 2007 | 10:09 PM
vincentjames501's Avatar
Most people on the vette forums just change their clutch fluid ever 5-10k miles. Its not that big of a deal
Old Dec 10, 2007 | 12:10 PM
PA Z06's Avatar
yes this is true, I change the fluid in clutch res, when it changes color.
If I were you I would start changeing the fluid, if you do it enough you will have replaced the entire system, because with out a remote bleeder its a PITA to change the clutch fliud.
Heres a great link to help
http://www.rangeracceleration.com/Clutch_Care.html
Old Dec 10, 2007 | 11:16 PM
i was changing my fluid once a week, i use rangers advice but i still have the problem. i claen my fluid one day and by the next its already black.i already replaced both the master and salve and still have teh problem
Old Dec 11, 2007 | 05:47 AM
PA Z06's Avatar
I think that means the system is still dirty, I would keep flushing it untill it stays clean for longer then a week, have you ever fully bleed the system
Old Dec 11, 2007 | 10:42 AM
i took it to get fully bleeded twice
Old Dec 11, 2007 | 11:04 AM
bzettler83's Avatar
doesnt look like the place you are taking it to is doing the job
Old Dec 11, 2007 | 11:34 AM
H82BU's Avatar
I think I am going to the ranger method to use what is left of my stock clutch...the guy before me did it and replaced the fluid with what he said is the top of the line....some blue stuff....?.....but it still crashes....BAD
