Corvette Performance
C5 | Z06 | C6 | ZR1 | C7
Which has more horsepower potential - LS3 or LS7
Old Jan 29, 2008 | 04:56 PM
Petsche's Avatar
Default Which has more horsepower potential - LS3 or LS7
Which engine can you get more horsepower out of while keeping the risk of breakage low and without changing any major internal engine components - an LS3 or LS7?
Old Jan 29, 2008 | 05:00 PM
whatsgrip?'s Avatar
thats a good question... I wanna know too...
Old Jan 29, 2008 | 06:05 PM
lionelc-5's Avatar
Maybe the LS3 because of the lowert compretion you can run more boost.
But that question is a bit broad, what kina power adders you talking about?
Old Jan 29, 2008 | 06:07 PM
ChucksZ06's Avatar
The LS7. It has better ports, better valve angle, better intake manifold, and larger bore for less valve shrouding, lighter rotating assembley and lighter valvetrain, rods and crank are better than ls3. That is just some of the differences...both engines have cast pistons which is a weak point.
Old Jan 29, 2008 | 06:15 PM
Cole Train's Avatar
yeah but i've read the LS7 can't handle much boost. Just what i've heard~Cole~
Old Jan 29, 2008 | 06:30 PM
blown4.6's Avatar
n/a ls7 hands down
boosted ls3 I think aps made more power or very similar power with their turbo kit due to the lower compression.
Old Jan 29, 2008 | 08:00 PM
somws6bird's Avatar
Id say the ls3, the LS7's cylinder walls are much thinner than the ls3's. I think the ls3 has more potential because you can force more boost in it.
Old Jan 30, 2008 | 02:37 AM
LS1LT1's Avatar
For an NA application (which might involve internal changes and wouldn't exactly fit the criteria here...or even just bolt ons) I would think the LS7 would still be better but if going forced induction or nitrous I would think that the LS3 (and LS2) might be better.
Old Jan 30, 2008 | 03:10 AM
Jersey_TA's Avatar
I'll take either motor in my C5
Old Jan 30, 2008 | 07:56 AM
ls1290's Avatar
Dumb Ass Vette Moderator
For NA or Nitrous the LS7 hands down. The 'nice' thing about nitrous is that it is not affected nearly as much as FI for higher compression. My old 383 was running 12:1 and it loved nitrous For FI, the LS3 is a far better choice.
One thing to keep in mind, the risk of breakage goes up equally with increacing the horsepower above stock.
Keith
Old Jan 30, 2008 | 10:16 AM
Ragtop 99's Avatar
Since your criteria is " without changing any major internal engine components", I'll take the cubes from the LS7
Old Jan 30, 2008 | 01:21 PM
scramblerman's Avatar
n/a=LS7 stock
F/I=LS3 stock
I'm sure with a LS7 with a bit lower compression would be great for F/I. Theres no replacement for displacement.
Old Jan 30, 2008 | 06:43 PM
slt200mph's Avatar
To put is simply ... There is no replacement for displacement...bigger is better ...
