Corvette Performance
C5 | Z06 | C6 | ZR1 | C7
metallic sound??????
Old Mar 10, 2008 | 03:52 PM
fastvet's Avatar
Default metallic sound??????
hey guys, this just started yesterday. i started hearing a rattling noise coming from the middle of the car. Sounded kind of metallic. I am running a spec 3 clutch and stock throughout bearing. I really dont know what it is and its pretty worrysome. it starts when I start rolling, and the noise stays there. As far as the clutch slipping, its not. it engages fine and takes off with power. Just thought i'd get some imput before I tear it apart!
Thanks
Old Mar 10, 2008 | 04:14 PM
stopltracr's Avatar
Does it sound like this?
http://s41.photobucket.com/albums/e2...lutchmovie.flv
I found this on another thread here. I also have a SPEC Stage 3 Clutch and an aluminum flywheel and mine makes this exact noise when it's cold.
Here is the original thread:
http://forums.corvetteforum.com/show...t=clutch+noise
Old Mar 10, 2008 | 04:26 PM
fastvet's Avatar
I'll check out the website in a bit when i get home, I am at work and they block that **** here. But mine started making it when I went on my 300 mile trip this weekend. even when it was hot. So, its not a cold thing.
Old Mar 10, 2008 | 04:49 PM
fastvet's Avatar
Listened to the video, but my is more of a clangy noise(clink clink).
l
Old Mar 11, 2008 | 07:37 AM
fastvet's Avatar
bump...
Old Mar 17, 2008 | 10:16 PM
00turboT/A's Avatar
Its your throwout bearing most likely> Push you clutch pedal down and see if it goes away. Most vettes are bad about that.
Old Mar 18, 2008 | 08:41 AM
fastvet's Avatar
^I think thats what it also sounds like. Anyone know of a good throwout bearing I can order. One that can handle about 6500rpm's??
