Heads/cam build on my C5:)
so i can take my time. Although i don't plan to
I should have it mostly tore apart tomorrow and then maybe clean up all the parts that go back on and get the cam in the car probably. i should have it done in 3 days with the motor and started up. Then i'll do the HUD install and probably lower the car last:driver: YAY!!!~Cole~P.S. TSP 228R cam, Z06 heads, TSP headers, oil pump, ARP studs, ASP underdrive, LS6 intake, Z06 Ti's, HUD install and Lowering it
~Cole~ The Best V8 Stories One Small Block at Time
Cam is in and i've got the timing perfect. i tried it 4 times to make sure. Dot's line up everytime #1 is TDC. Now i'm basically check tq. specs and making sure i got 'em right. ~Cole~
i got f*cked by a member. Told me the ARP studs i bought were for the pre '04 blocks. I went to double check the box number and low and behold they were for a '04+ block
SO now i paid $100 to Next day Air some right ones from TSP
~Cole~
Pics below:~Cole~
P.S. Also HUD is IN the car and just waiting to reinstall the dash so the Epoxy set's up good.
