OK, What to do next? C5 Performance
Tim
I was on Nittos DR's set at 21psi short heat up, and couldn't hook for ****. 2.11 60 and 12.02 1/4 at 123.6 mph into a headwind.
Our 98 with 176,000 miles on it runs 11.30's with 3.42 rear, 4500 stall, mild heads/cam & ET streets for traction. 60' is 1.53 range. Only dynos at 330 rwhp w/convertor unlocked. So I'd say you have a pretty good combo now....just need to get the traction down.
If your car is driven a ton, buy some used rims and have a set of track only tires. If you put less than 10,000 miles per year on your car, I'd buy nittos and run them all the time. They help a lot on the street too. Once a year you'll buy new rubber.
BTW where are you located? Altitude and humidity play a big factor.
Though Nitto's might not be that bad.
