402 with sts stage 3 turbo twins
This is a texas speed 402 with calies rods/crank and diamond boost pistons.
The heads are AFR 205s hogged out so that they flow 318 at .600 lift
This is an sts kit with stage 3 ball bearing turbos. They are supose to be the gt35r equivalents although i had a smaller exhaust housing put on to help with spool time and for more torque.
All i have left is the charge piping and filters.
Yes, that is also a nitrous fogger. No lsx car is complete without spray!
This is the ls6 block that was in the car. There was less then 30k miles on this block when i pulled it out. I ran 10.50 at 135 with it. Its still in great condition.
I will be breaking it in by monday, and installing the fuel system after that (will be awaiting lonnie's pumps).
Good times.
Good times.
Thanks for the compliments. The set up is going to probaly be more along the lines of a weekend warrior. I make car payments on this thing so I cant make it a track only car yet.
I was at the PRI autoshow/convention in orlando when i bought it. They gave me 30% off their kit for ordering it at the show. I got all the upgrades (stage 3 ball bearing turbos, second waste gate, bov, etc). The kit was 7100 to my door.
