Corvette Performance
C5 | Z06 | C6 | ZR1 | C7
Make your own ZR1?
Old May 24, 2008 | 01:51 PM
SVTBAIT's Avatar
its not just the FI its a damn ZR1 with alot of goodies all around
Old May 24, 2008 | 03:04 PM
Urban Legend's Avatar
TECH Cry Baby BOSS APPROVED!
Originally Posted by Ragtop 99
A better question would be how does the ZR1 compare to a modded Z06? I know there are mods other than power, but at least you start with a better platform and wider tires with a Z06 compared to an LS3 coupe.
The ZR1 S/C will give some amazing low end TQ, but a set of headers and a good cam puts the Z06 performance up there in the 4000 - 7000 rpm band where races are won and lost. Of course, its not 50 state legal like a ZR1.
And don't forget the all important manufacturer warranty.
Old May 24, 2008 | 05:42 PM
sslateron's Avatar
Well, how bout the Z51 performance option, that is good for .98 on the skid pad. You have slotted roters with it too. The ZR1 is just over kill. Your only going to see a few hunderd or maybe a thousand or two. My point of this thread is for the price of a supercharger, and maybe a few other mods you will be in ZR1 territory.
Old May 24, 2008 | 10:32 PM
Phynix's Avatar
no, you wont. the brembo brakes are $16,000 alone to get the same stopping power the zr1 has, also its suggested that you forge your bottom end when going with 12lbs of boost to get the 540rwhp, plus the cost of strengthening up the trans & rear, buying a twin disc clutch, all the carbon fiber, wider rims and tires, tuning. There is no warrenty left after that as well. & after all that someone with a zr1 needs 80$ for a pulley to add more boost
Old May 25, 2008 | 05:36 AM
Maybe in a short straight line run. But with the improved ZR1 aero you still won't touch it at hyper speeds.
I am done here.
Old May 25, 2008 | 10:29 AM
OKcruising's Avatar
It costs a lot to get to and supercede the zr1 level. I got the receipts to prove it...
Frankly, the zr1 is dirt cheap for the entire enchilada it provides
Old May 25, 2008 | 11:21 AM
BlownVette 2001's Avatar
I am done here.
I have a highly modded C5 (use to be a coupe/now an FRC) with a stealth wide body kit by ACP.
I would have no problem hang'n at high speed with the ZR1.
BTW, I have all the supporting suspension and brake mods too, just need to figure out what FI route to go.
I would post up some pictures but is in paint at the moment.
Panel Fitting
Painted Panels waiting for reassembly.
Old May 26, 2008 | 07:08 AM
OKcruising's Avatar
Blownvette, you might want to check out some oiling systems if you haven't at least gone to a modified LS7 Drysump system with a better pan design. just 1.0g lateral will have you blow an engine in a very short amount of time if you don't pre-empt it
Old May 26, 2008 | 09:27 AM
I don't plan to track the car so I don't think I need to go as radical as a dry sump but will probably throw in a accusump system for the just in case times.
I won't have any problems pulling 1G in a turn especially with some sticky rubber. Car has Pfadt coil over and competetion sways, VBP poly bushings, moog and spicer ball joints, VBP HD tie rod ends.
I'll be running 305/19/30's and 345/19/30's PS2's on the street. Once I get every thing sorted out I'll look into a 18" package for high performance runs.
My track will be 4" wider in front and 6" in the rear.
Thanks for the advice.
Old May 26, 2008 | 10:03 AM
OKcruising's Avatar
I've heard good things on the accusump as well. I didn't know your intention as that determines the severity. I look forward to the end of your body mods, especially how your fitting 345s, as I can't run a tub, I'm digging the pics.
Old May 26, 2008 | 12:10 PM
Vindication's Avatar
a ZR1 is a pretty well engineered package but if you want to beat one going straight its possible to do for a lot less money
Old May 26, 2008 | 05:25 PM
  #32
I'll have no problem getting 345's on as I have a wide body, no need to tub. Fenders are 3" wider on each side.
Old May 26, 2008 | 05:31 PM
  #33
'Trust''s Avatar
^ Any more pics or info? Looks like an awesome build!
Old May 26, 2008 | 09:17 PM
  #34
There are a few pictures in post #27 above. All the panels and roof are apart for painting.
It's probably going back together soon. I'll have to drop ACP an email and check on it.
I travel alot for a living and I am in Minnesota at the moment.
Thanks.
