Corvette Performance
C5 | Z06 | C6 | ZR1 | C7
2002 zo6 ebcm
Old Jun 29, 2008 | 03:38 PM
welldonecj7's Avatar
Default 2002 zo6 ebcm
One of the cars my dad is looking at reciently had the EBCM replaced, owner states it had started to act up. I know there are quite a few posts about this happening but I was just wondering if this is more frequent for an 02? I have read some about different sized wheels causing this problem, is that true? This seems like a fairly common problem from what I have read, once it has been replaced do they normally continue to have the problem or is it generally fixed?
Old Jun 29, 2008 | 07:02 PM
k-mart's Avatar
Generally, they are fixed by replacing the ebcm. If that doesn't correct the problem it is probably a grounding issue and there's a ton of them to locate and clean up. Good luck if he purchases the car.
Old Jun 29, 2008 | 11:41 PM
would it be something that is a cause to stay away from this car and look for others, or is it not that big of deal?
Old Jun 30, 2008 | 02:57 AM
Quik Z06's Avatar
Its pretty common, our ebcm on our Z06 has been rebuilt and it's not expensive to do. You can get it done for about $150. Dont let that worry you at all.
Old Jun 30, 2008 | 03:02 AM
Alright thanks, I didnt really know much about it untill the guy told me about it and then i read about it a little by searching on here but didnt know how frequent it was or if it is something that would cause you to want to stay away from a car.
