question about c6 heads
thanks guys for help
Look for the crank trigger sensor on the front cover of the motor(used LS2 you speak of). If it has an electrical sensor on the front(3 or 4 pin connector) attached with one 10 mm bolt, and it's aluminum, there is a pretty good chance thats an LS2. Those all came with "LS6" 'D port cylinder heads. In other words, the exhaust ports should look like the letter "D" laying on it's side. Stock LS1 heads would be oval(ish).
All blocks come with there LITER marking on the front or back o the engine. 5.3,5.7,6.0,...etc.
If it doesn't have an intake manifold on it now, there should be NO knock sensors sitting under the manifold, or, on the top of the engine,. The LS2/L92 knock sensors would be located further down, on the sides of the block.
The LS3`s have L92 heads and those heads will not fit with stock or Fast intakes, those L92 heads need the L76 intake. As of now there is no intake available except the L76. But Fast and Weiland will be out soon with there intakes for the L92 heads.
Hope this helps.
Keith
i learned new informations from you
Hope this helps.
