Corvette Performance
C5 | Z06 | C6 | ZR1 | C7
installing an aluminum flywheel any tips....
Old Sep 1, 2003 | 02:05 AM
U LUZ's Avatar
Default installing an aluminum flywheel any tips....
i have to pull my tranny again in my zo6 and im going to insall a fidanza flywheel will this work with the stock clutch??????{it looks cool,and it is a lot lighter than my stock flywheel}...
Old Sep 1, 2003 | 01:43 PM
66ImpalaLT1's Avatar
Default Re: installing an aluminum flywheel any tips....
Fidanza should work with the stock clutch. You might want to check the manual transmission section of this board. I read that fidanza does not surface their flywheel after installing the insert.
Old Sep 1, 2003 | 11:56 PM
U LUZ's Avatar
thanks for the info i will check....
