The Hot Rod runs a new PB
We went to Pinevalley Raceway 3-29-09 and ran a new PB.
6.420 at 105.44 1/8 10.1514 at 131.66 with a 1.3126 60 ft 1/4![Chug! Chug! Chug!](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_chug.gif)
Weather
Temp-66.5
Humidity-32
Barometric Pressure-29.24
DA-Positive 1424
This with a LS1 347
5.3 Truck Heads
30x9x15 Slick
5000 stall convert
Turbo 350 Tranny
4.56 gears
Race weight 3180
They race didn't work out the way we wanted. We out in the 2nd round. We had a Spark plug issue (we think)![MAD](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_mad.gif)
Coach
Weather
Temp-66.5
Humidity-32
DA-Positive 1424
This with a LS1 347
5.3 Truck Heads
30x9x15 Slick
5000 stall convert
Turbo 350 Tranny
4.56 gears
Race weight 3180
Coach
LS1 Tech Administrator
Dang, one round. Once you get your issues sorted out, I look forward to seeing more PBs from you Coach.
![Happy](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_stretch.gif)
__________________
![](https://ls1tech.com/forums/signaturepics/sigpic210_1.gif)
2013 Corvette Grand Sport A6 LME forged 416, Greg Good ported TFS 255 LS3 heads, 222/242 .629"/.604" 121LSA Pat G blower cam, ARH 1 7/8" headers, ESC Novi 1500 Supercharger w/8 rib direct drive conversion, 747rwhp/709rwtq on 93 octane, 801rwhp/735rwtq on race fuel, 10.1 @ 147.25mph 1/4 mile, 174.7mph Half Mile.
2016 Corvette Z51 M7 Magnuson Heartbeat 2300 supercharger, TSP LT headers, Pat G tuned, 667rwhp, 662rwtq, 191mph TX Mile.
2009.5 Pontiac G8 GT 6.0L, A6, AFR 230v2 heads. 506rwhp/442rwtq. 11.413 @ 121.29mph 1/4 mile, 168.7mph TX Mile
2000 Pewter Ram Air Trans Am M6 heads/cam 508 rwhp/445 rwtq SAE, 183.092 TX Mile
2018 Cadillac Escalade 6.2L A10 Pat G tuned.
LS1,LS2,LS3,LS7,LT1 Custom Camshaft Specialist For custom camshaft help press here.
Custom LSX tuning in person or via email press here.
Race your car!
For an n/a stock CI car that's moving pretty good... get the bugs cleared and you shoudl see a 9 second pass this year.
I'm not 100% up on the weather down your way, how does that stack up to a really good weather day? Just a night run alone might get a 9 second slip out of the car yes?
To me up here in new england at our track that's at a 660 foot elevation if I could get that kind of d/a all the time I'd be loving life
![The Jester](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_jest.gif)
Very fine run coach,seems the new cam is doing it's job. More seat time and some late afternoon runs in that DA and you should run a 9 sec. pass easy.
JL,i live 5 hours north of coach and i would kill for that DA
It's pretty much luck of the draw around here. Most of the time the killer DA is on a Monday or wednesday haha! atleast that's what me and some of my buddies joke about.
![Grin](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_grin.gif)
Thanks everyone. I am looking forward to some better air to maybe finally run a 9 second N/A time.![Angel](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_angel.gif)
The problem with the car was in the second round when I took the car up to 3500 rpms it acted like she was on the 2-step. She ran way off down low. lost 3 mph in the 1/8 and only 2 mph in the 1/4. I stopped at the end of the track and took her up on the convert, same thing. Took off and she was spiltting and stuttering until I shifted into 2. Instead of hurting the car I put her on the tralier and headed home.![MAD](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_mad.gif)
When we got back to Houston last night we pulled the valve covers to make sure we didn't brake a valve spring. They were all good. We pulled all the pugs and they looked good. We checked to make sure all the header tubes were hot, good they were good also. Convert had not be hot. After checking everything we could think of we start her up and took her up to 3500, worked like a charm. I don't know what happened. Maybe we had a loose plug wire or have a plug going bad. Afler looking at my log books we have almost 200 passes on the plug in the car now.![Bang Head](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_banghead.gif)
Needless to say a fresh set of plug will go in her tonight. With the help of one of my new sponsors we plan on going to Little River Dragway this weekend to do some more 1/8th mile racin.![The Pimp](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_pimp.gif)
Coach
Coach
Coach
Coach
Race your car!
200 passes on the same plugs !?! Jesus I didn't think there was one that would last that long!
I don't think I've made more then 5 runs on the same plugs yet. Probably overkill at my level to be changing them every trip and then some like I do... but still.
Whatever plug you run, order a case of them. Usually they'll knock a little $ a per plug price if ya buy in bulk, at least my local autoparts store does. The look on the guy's face when you tell him ya want 120 plugs is priceless too![The Jester](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_jest.gif)
I'd swap the wires too just for the hell of it.
