My WS6 w/ L92 heads, 408ci, TH400, Vig 3600, 3650lbs, 325 drag radial | NA Times
#41
#42
I doubt he's gonna be coming off the brake with a nitrous set up and a tight converter on the 325's. Especially how heavy he is and little weight transfer a heavy car gets.
I couldn't get my old 408 to leave off the brake on the 325's N/A (no 2 step though)
I'd like too see that car cut a 1.38 at that weight, on those tires with his current set up.
I'd raise an eyebrow for sure.
#43
Yeah but that was with your turbo car no?
A 1.38 60ft with a 111 mph that I should get from going 630-650rwhp to my 710-740rwhp setup should put me in the 5.90-6.10 range in the 8th for sure. Last time I made low 600's horsepower the car was on a 150 pill....
It took 11 degrees of timing (normally runs 15 degrees) and a cold bottle to make that low of power. This was intentional as there was a fuel pump issue the last trip to the track.
#44
Last night the car went a 7.17 @ 96.9 mph with a 1.61 60ft off a footbrake.
It also did a new best on the hose with 650rwhp. Lets just say that the 8th mile time would put it in the 9's in the quarter. I plan to run the car in the fall with 82 degree temps and 750rwhp. Should put me in the 5.90's or so?.........
6.40 is around a 9.99.
5.90 is a 9.25
(ish)
My 10.58 was a 6.70 1/8 mile.
Does the car spin or wheelhop off the transbrake? Double adjustable rear shocks would do wonders.
Multiply your 1/8 mile ET by 1.57 to get 1/4 mile et.
ex 6.31X1.57=9.90
Going from a 9.90 to a 9.20 is a whole different animal than going from a 11.0 to 9.90.
Good luck though.
#48
I should have said "cure". I dont think that will allow me to hit the car with a T-brake with a 325........ I wonder how folks get cars to setup to go. I do not have the knowledge to setup a car to hook on a drag radial and I don't see the 275 guys hooking every pass.... too darn finicky.
#49
https://ls1tech.com/forums/nitrous-o...-275-race.html
its all in the suspension ....yes you need front shocks to transfer the weight ... , a lot of T&T .....there are guys hooking on the 275's and plenty of guys going on 325's
#51
Stick a progressive controller on your nitrous Wise...really helps out on these DRs. Im able to dead hook on a 275 with times similar to yours but better 60s on a progressive box. See ya at the track.
#52
I have a setup, very similar to the OP. 413 cid LS2, t400, 3.73, 3600 Yank stall, ported L92's and 3460 lb raceweight. I am running a stock L76 intake and my car goes 6.9's in the 1/8th @100 and 10.8 @ 126 in the 1/4. My car went a best of 10.5 @125 with the old 4000 Yank, but I put in a tighter converter with intentions of spraying the car just like the OP. I am also running stock front and rear shocks. To me it sounds like somthing isn't right with your combo. My 60' times are also only 1.58- 1.60 with the new nitrous converter. With the old converter it would go 1.39 60' times.
Our setups are nearly identical, with nearly identical 60' times, but I am trapping 6mph more than you in the 1/8th. I am guessing there is somthing in your setup that is holding you back. Maybe the single plane intake?
Either way, it looks like your car is responding well to N20. But I agree with everyone else when they say, dial in your NA setup and it will only help your N20 times.
#53
I have the dyno graph from last week. Keep in mind the car only made 1 nitrous pass.
also here is a video of the one and only pass with the same horsepower:
<embed width="448" height="361" type="application/x-shockwave-flash" wmode="transparent" src="http://i24.photobucket.com/player.swf?file=http://vid24.photobucket.com/albums/c15/forteen3gt/MVI_1529.flv">
http://s24.photobucket.com/albums/c1...t=MVI_1529.flv
#54
as you can see this is not leaning on it whatesoever. It made 710 before with these same pills more timing and alot more bottle pressure.
#55
no comparison....
I drive my drag radials on the street which doesnt really make them a drag radial due to change in heat cycling etc.... as explained to me by someone that knows how DR's work and hook on a 275 wide True Street car.
#56
LS1Tech Co-Founder
OP, do you want our input are you all set. 5.9x's in the 1/8 is going to be a bit of work. If you are making 700rwhp you can run mid 9's and get close, just have to work your time down from a 6.3 to a 5.9. My old 2000 Z/28 went 10.008 on a 150 shot on top of stock cubes (10.9@122.5mph NA), and to run 5.9's it would need probably need a 225 shot in my case.
#57
I appreciate the input. I also want to share my results for folks to use as a means of measurement although they are not ideal conditions or optimized.
#58
I will say the both of you are making me feel real good about the way my car is performing being only a 346 CI engine and on 26 inch tires to boot! My car is always at the 100 MPH mark in the 1/8 NA.
Anyway I hope you get it figured out WizeAss! Sometimes it just takes time. For what it is worth I would have put the front shocks on first before I ever even changed out the back shocks. I have been many 1.4 sixty foot times with the stock shocks on the back.
Good Luck!
N2
#60
Thanks John... that is what the shop and most others have figured. I have a feeling the car will get close to 98-99mph NA with the right temps. Doing 111mph sure does put it close.... we will see in cooler weather.
