first trip to the track went really well i think?
Well this was my first time to the track, I had very low expectations because this is the first car i have taken to the track and my first trip to the track. ive had the car for about a year so ive learned how to drive it pretty decent (its an auto)
my best time was leaving from idle and close to slamming the pedal down. i was hooking like crazy, all three runs i did i didnt spin at all. temps were probably about 95ish.
60 FT : 2.0
1/8 ET: 8.6
1/8 MPH: 84
DA was 2066 when i was racing.
are those decent times for my car (see sig)
60 FT : 2.0
1/8 ET: 8.6
1/8 MPH: 84
Its decent, but it can do better. In hot weather my car usually slows down like 2/10ths but (traps same or higher though). I would think you should be trapping higher mph with all those mods. Do you have 2.73's?
Maybe you should try to stall it a little higher , to like 1800rpm, that should help if you get traction.
its an ss so i have 3.23. im sure ill get the time down quite a bit with my seat time like coach said. and im sure if i stalled up it would do a lot better. but i just wanted to see what would happen if i left from idle. that and my car is set up for autox
