ms3 in the 1/8
Old 11-09-2009, 04:52 PM
Mightymike2000ss's Avatar
Location: Home town Clive,IA current town FORT BENNING GEORGIA
Default ms3 in the 1/8
hey guys, im running the mods in my sig(MS3). Im just curious to see what some people ran/trap speed.
Im alittle shy to say that the best time i could dish up on street tires was an 8.6 with my highest trap speed being i think 89mph with a solid 2.0 60ft.
im sure i could have been running better times but i was running my stock master cylinder and really couldnt get it in third not to mention i was sitting sides down half the track..
Old 11-09-2009, 05:32 PM
TJ
TJ's Avatar
most everyone ive seen go down the track in my area is 7.30-7.40's @ 93-94mph.
Old 11-09-2009, 05:35 PM
camscam02's Avatar
6.95 at 96
Old 11-10-2009, 06:09 AM
spook99maro's Avatar
I dont have ms3 times but i feel ur pain. get some slicks on that beast and go to town. when my car was stock i dropped .7 off my times by getting m/t et street radials and learning how to launch on those. m6 and street tires = slip and slide
Old 11-10-2009, 11:42 AM
PowershifterNC's Avatar
get an adj. master from Tick..that worked wonders for my car..now I can shift @ 6700 or later and no problems
Old 11-10-2009, 02:29 PM
thank god im not alone hahaha. i actually did get the tick master cylinder now i can bang gears in my car. what was really cool about the ms3 is that i raced and 80's monte carlo with slicks and a 383. he easily pulled hard off the line by 2 or 3 cars right at the end i pulled right up to his door couldnt get it in third and he ended up beating me by a car i was so pissed hahah i could of had that win
Old 11-26-2009, 05:20 PM
MATTREDSS's Avatar
my best so far has been 7.17@94mph
Old 11-26-2009, 06:39 PM
slowlsx's Avatar
something is definately wrong that ur only trapping 89mph... whats your DA?
Old 11-26-2009, 07:16 PM
74ta's Avatar
I agree from the mods in your list you should still have alot more mph in it. I have about the same bolt on's and a tr230-236 and trapped 90mph,8.20's on street tires,and2.08 60'. This was on a hot and humid day in june,116mph in the 1/4.This is with stock heads and injectors. Hopefully that shifting problem was robbing alot of your potential. good luck.
Old 11-26-2009, 07:55 PM
im not really 100 percent sure, but im almost sure the problem was my master cylinder. i couldnt get it in third... also im lacking a tune so that should have another part of it
Old 11-26-2009, 08:26 PM
s346k's Avatar
uh. i'd expect much more from a setup like that mphwise. i'd expect a head/cam car to easily be trapping 95+. are you racing in the mountains or something? being untuned definately isn't helping, but i've seen m6 lid/muffler cars trap 87-88 at full weight all else stock.
all of the local ms3 cars were very slow given the size of the cam. they all trapped about what yours does (and some less)...which i give to a poor tune. i have seen very few ms3 cars run to their potential, be it the tune, driver, whatever..
Old 11-26-2009, 08:28 PM
im in iowa so it isnt that bad up here
Old 11-26-2009, 09:51 PM
BayAreaSS's Avatar
you should be trapping about 96 in the 1/8th with that set up. Hopefully the tick helps you out
Old 11-30-2009, 08:33 AM
1badzo's Avatar
I went 7.20@96 with a MS3 and a fast on stock 241 heads. This was done with a A3 and a 4000 converter.
Old 11-30-2009, 11:50 AM
Magnet's Avatar
Don't worry about not going fast yet.. get everything figured out first and then judge it, you can't judge a car when its not shifting right and on street tires..
Old 11-30-2009, 01:32 PM
Silver99tA's Avatar
i ran 8.4 at 89 on stock tires and stock everything else....now with all the mods and 555r's im running 7.6's
Old 12-03-2009, 09:19 PM
1Bad97WS-6's Avatar
I went an 8.70@83.86MPH with a 1.995 60ft. With just a Lid,K&N,Delphi 85mm,Throttle body Bypass,Smooth Bellows.Stock A4 and 273 gears with street tires. Know I have SLP Y,SLP Loudmouth 1 Catback. I havent had time to take it back to the track..
Quick Reply: ms3 in the 1/8
