First time at the track
Old Dec 6, 2009 | 06:12 PM
mknight759's Avatar
Default First time at the track
ok here it is hooked good off the line but spinns all the way from 2nd gear to the end of the track this is on 25$ used street tires tell me what you think This is in a 02 s10 standard cab going to get some mt radials and try it. You can feel it pulling good then it just quits when it starts spinning i figured i am losing .5 from the smoke show
2.06 60ft
5.70 330 ft
8.38 et @ 594ft
8.96 1/8 et
77.20 mph
Old Dec 6, 2009 | 07:38 PM
Carter01's Avatar
2.06 60ft
5.70 330 ft
8.38 et @ 594ft
8.96 1/8 et
77.20 mph
Give us some more details on the truck (motor/tranny, mods etc) kind of hard to give an educated reply right now.
Old Dec 6, 2009 | 07:40 PM
mknight759's Avatar
ls1 stock bottom end stock 243 heads ls6 intake& tb pp 225/229 cam 4l60e 342 gears 26in tall tire 3200lbs
Old Dec 6, 2009 | 07:47 PM
Carter01's Avatar
Sticky tires are a must for you my friend, your trap speed is mighty low however. I think until you get some tires it will be hard to tell if your mods are working well together. I would think with that combo, plus a stall at 3200lbs you should run mid 7s in the eighth mile, maybe a little faster.
Old Dec 6, 2009 | 07:49 PM
mknight759's Avatar
k thanks going with a yank 3000 or an fti after the first of the year
Old Dec 6, 2009 | 07:54 PM
Carter01's Avatar
Cool, I'm not real familiar with your cam shaft but my car at 3450 lbs with a 6spd spinning off the line pretty bad goes 7.5 in the 1/8 @ 93mph. Even if your cam doesn't make as much power as mine you weigh 250lbs lighter so when you get your stall and get a good launch you should be right there with me, also make sure your tune is spot on! Good Luck
