Nwe times w/402ci/l92/vic jr elbow intake.
car is a 01 ws.6,m6. 11.0 comp 402ci,ported l92 heads, cam by Pat g, kooks,open cutout, 12 bolt w/4.11's. Tires,front runners and M&H racemaster cheater slicks 26x11.5x15. car made 530hp @6,900rpm's 460tq.Dyno sheet was posted in dyno section. Car weights 3,480 and i'm 215lbs=3,695
run#1 left at 6,500rpm's off the two step.
1.44 60
6.95 1/8
10.85 1/4
127.66 mph.
I hit the rev two times but i shifted so fast i don't think it hurt it by a tenth at most.
run#2
1.44 60
6.90 1/8....didn't hit rev this time........but........
that was all car will not go into gear at all,I never got to 3rd.
car went home on a flat bed.
I think the car has a very high 10.7 in it,but not this time. as Arnold says....I'll be back!
1.44 60
6.95 1/8
10.85 1/4
127.66 mph.
run#2
1.44 60
I made no mods to the car at all for the 26x11.5x15 tires. My clutch went,I will get a 1.39 or better 60 foot from this thing this year. I think you will be happy. don't be afraid to come out hard on them. I ran at 13psi cold on these runs. The guy taking pics told be to add 2lbs of air so they don't wrinkle so much and i'll go faster. I didn't get the chance.
Your car sounds tough. And did your own tuning,nice. How did you do your own catless y-pipe?
SMOKEDOUTZ28-Those rims are bad ***,they look sweet. I need to get a set. are they heavier then a stock 17x9 stock rim?
I like your setup, seems to be the exact thing I'm looking and hoping for out of my 402 when I finish the build.
A friend and I built the Y pipe out of some material we got from a muffler shop. It was a pain in the *** because we have never buillt anything like that before. Cutting pieces and welding, making pie cuts and getting it to all line up. I used a 3" to 3.5" flowmaster merge collector. It's not real pretty at all and its not mandrel bent, but oh well it works for now.
I have gone through 2 slave cylinders and 2 master cylinders now because my damn pedal keeps sticking to the floor. I hope you get your clutch issues figured out I know how frustrating it can be.
Sorry to hear about your trans issues. Must have been frustrating to get a 10 sec slip on the first pass and then break....
Nice to see another 10 sec 6sp on here though and congrats on a decent first pass for a full weight car.
Mike
Mike
It don't look pretty,but if it gets the job done that's all that matters. This clutch was in my car for three years. I pulled it for a new one and my slave went and got fluid on the new clutch. I put my old one back in and it didn't last long.
Thanks. I was like no way when the car went down. I'll be back soon. Trick flow has a l92/ls3 head coming and it should be a killer head from what i hear.
I hope to add them and get a 10.5 pass.
Hope you get the trans sorted out soon.
Mike
I'M RUNNING A SPEC ST3+. I tried three rams and centerforce,all sucked in my car big time. The spec is the only clutch that will last. I shift this motor at 7,100 rpm's. You can see the dyno sheet in the dyno section. I think it's the clutch and not the trans. I think the press-plate got stuck or bent and fried the clutch.
I was told The trick flow l92/ls3 head will be out around christmas or first of next year. Ed at trick flow and I have talked and t.e.a is working with them on the heads. Ed tells me they are working to give a great head that will do the job.
I do not know about a intake,you can call Ed at trick flow for info.
No need to doubt it. Car weighs 3820 without the bottle in it. and has been 10.97 at 126 with a 1.49 60 ft with 4.30 gears and 28" tires. and only going through the traps at 6900 in 4th.
Someone needs MOAR GEAR
Yes,no way he has a l76 intake. my car peaked at 7,000. but from 7,000 to 7,500 it only lost 9hp. I'm going to try a new elbow over this edelbrock and see if i gain.
3820lbs car how is it so heavy? do you have my ex wife in the trunk?lol
What kind of power does your car make?
