Finally got to make a pass
After reviewing my pass it looks like I did a real shitty burnout. I swere it felt like I was roasting those tires forever (newbie). Please please please make 3 clean shifts. Pull up to the light and dump her at 5000 rpm WOT, dear god never felt it launch like that before! Made 3 granny shifts and it never went to the floor, short shifted 3rd but oh well. Wish I could have made more passes than 1 clean pass but I'm sure I will have all summer.
Raceweight: 3700 + lbs
Elevation: 2200' MAP reading @ WOT 94-95 kpa
DA: 2500-2800
60': 1.711
330: 5.018
1/8: 7.753
MPH: 90.41
1000: 10.106
1/4: 12.066 So close to 11's
MPH: 115.78
Buddy with his L92 intake / head 408 th400 3500 stall, 12 bolt 4.10 gears also ran a new person best of 11.73 @ 115 mph with a 1.6 60'. Our track seems so slow I don't get it, ever since they redid the timing system last year everything is .3-.4 slower and 3-4 mph less.
Not a bad 60' for a lowered SLP uplevel suspension car right? I still am on stock LCA's for now. All I did was unbolt one link on the front sway bar. Also have an airbag in the passenger side @ 5psi (is this too low?)
Crappy video I know, sorry.
http://www.youtube.com/watch?v=ZefjEl-sRmk
Edit: Wonder how much power my 21 lb driveline and 9" with 140 wt syrup in it robbed over the 10 bolt? Guess I should throw it back on the dyno.
Oh well time for another clutch! I did find this though for Spokane, WA NHRA altitude corrections http://www.nhra.com/competition/altitude.aspx
94-95kpa,,, looks like you have a restriction in the intake somewhere. Still using the stock LS1 intake manifold?
Yeah, 2300 feet of elevation will def affect your trap speeds. You should make a road trip over here and run at 200 feet elevation.
Mike
3090 Density Altitude (2200' elevation)
3700 + raceweight
Going through dual dual exhaust
6800 RPM Clutch Drop
60': 1.646
330: 4.899
1/8: 7.580
MPH: 92.37
1/4: 11.820 *** Finally!! ***
MPH: 116.79
Time to open cutout and add a little fuel
60': 1.767
330: 4.969
1/8: 7.616
MPH: 93.54
1/4: 11.797
MPH: 118.23
Track was going away at the end of the night. I think it has 11.6x in it with the cutout open and cutting a 1.6 60'. I couldn't believe it bogged the motor down to 4000 rpm on my 6800 rpm drop! These M&H tires hook like a **** for being a slp lowered suspension car.
http://www.youtube.com/watch?v=sW05-CCq2iw
I could only hope with a little less weight, suspension and a nice crisp sea level track maybe some low to mid 11's ? The guy who specced my cam also said there is another 20 rwhp if I decide I want a bigger cam, but I don't know I love the way this thing drives.
I did set a new personal best with no changes to the car, except I banged the fug out of them gears!!Density altitude was much higher this time (hot!) @ 3981'
60': 1.725 Spun all the way through 1st haha
330: 4.923
1/8: 7.588
MPH: 92.4
1/4: 11.794
MPH: 117.95
Dragtimes corrections if you believe in that.
Stock and Mildly Modified Naturally Aspirated Engines
11.222 @ 124.029 MPH
Extensively Modified Naturally Aspirated Engines
11.372 @ 122.333 MPH
Damn I need a sea level winter track with mineshaft air like you guys run in with -1000' + DA!
. I think the dragtimes calculator is pretty accurate but under what category does a heads/cam motor fall? I figured it would be considered extensively modified. It would be really awesome if I could run at a -1000' DA track with setup suspension and a set of skinnies. I really think this mild setup would be turning some heads than, unfortunately those type of conditions do not exsist around here. I really think it would go 10.9-11.1 @ 124 + mph with a 3600lb raceweight. I'm going to throw my Chrs1313 ram air setup I built for it last year back on and see if that helps mph. Thanks for the comments guys, I will keep this updated!
