Streetsweeper cam results
#44
Maybe I need a different ram air? I have fast toys. I bet I need to raise my rev limiter. Its at 6200 rpms, rev limiter is at 6800. Anyone?
#50
Sometimes shifting higher can give you a worse et. Even if it's only a couple hundred rpms. I honestly think this is as fast as you are going to go this summer. Maybe this fall you can drop a couple tenths. Save for a 9" next year and run 11s. A lot of 12 bolts break while being turned by a manual. Then again some don't.
