slower after h/c install
Check all the plug wires to make sure they are all the way on.
Verify Fuel Pressure 55-60 psi. I had a failing fuel pump that didn't die all at once. It just kept getting worse until the car would barely run.
Check the pushrod length. This happened to me when I changed my first set of heads. Found out my pushrods were a little too long and was bleeding off cylinder pressure.
Most cam only fbodies I see run 90-93mph 1/8th depending on weight/cam size
