12.73 ET 110.83 MPH Cant Hook Up Suggestions Welcome
Alright First Time at the track was nervous for sure wasn't being gunho whatsoever.
For starters had 3/4 of a tank of fuel And I think I was Shifting into 5th
Reaction .9830
60ft 2.0041
330ft 5.4159
et 594ft 7.7420
1/8et 8.2577
1/8mph 87.25
1000 et 10.6971
1/4et 12.7340
1/4mph 110.82
Running on Nitto 555R 18psi 275/40/17 No Traction Launching at 2500rpm
MODS Are
Hooker Long tube Headers
Texas Speed True Dual exhaust
MTI Clear Lid
SLP Smooth Bellow
Comp 231/237 .598 .598 114 LSA Camshaft
TSP Hardened Pushrods
PRC double springs good for .650 lift
LS6 Intake Manifold painted red to match the car
Rebuilt T56 Transmission with the following parts-
Steel 3-4 shift fork
Bronze pads
Blocker rings
LS7 Clutch
LS2 Flywheel
Moser 12 bolt with 33 spline axles, C-Clip eliminators, and 4:10 gears
1350 yolk/u-joint
Alum Driveshaft
BMR torque arm
BMR SUBFRAME CONNECTORS
Hotchkis panhard bar
BMR lower control arms
Dyno tuned 360RWHP/355 RWTQ AFR's- 11.0
Wanting to purchase Hoosier Drag Radial or M/T ET Streets 275/40/17 or go full slicks on 15 inch rim
Next time I go to the track im going to do this
1/4 tank of fuel 94octane with ethanol or 91octane no ethanol or Mix either with race fuel?
Remove Rear Seat Jack and spare tire.
Air up the front tires to 40psi Cold
Empty Washer Fluid
New Tires
Try Different Shift Points
Any Launching Tips?
11s Possible
Reaction .9830
60ft 2.0041
330ft 5.4159
et 594ft 7.7420
1/8et 8.2577
1/8mph 87.25
1000 et 10.6971
1/4et 12.7340
1/4mph 110.82
MODS Are
MTI Clear Lid
SLP Smooth Bellow
Bronze pads
Blocker rings
LS7 Clutch
LS2 Flywheel
1350 yolk/u-joint
Alum Driveshaft
BMR torque arm
Empty Washer Fluid
New Tires
Any Launching Tips?
11s Possible
I would just go with husky 94, don't worry about the race gas and so on. Lightening the car is a good idea. Do you have lca relocation brackets? Might be something to put on the shopping list. Get your new tires first and see from there.
Here is a thread full of great info for 6speed drag racing. https://ls1tech.com/forums/drag-raci...cing-tips.html
1/4mph 110.82
1/4mph 110.82
Shifting into 5th is a good sign that you're doing it wrong. Invest the $50 or so into a shift light to help that problem.
110mph is very low for a cam car. I've seen as high as 116 in my stalled A4 stock cam car. You should be MPHing much higher, at least in the 116 neighborhood. Good sign that you're short shifting as well.
Work on smoothing out the launch. You shouldn't be blowing away Nitto DR's with a 2500 launch if there is a smooth engagement. People are quick to trash those tires, but they've worked well for the past 12 years or so. I wouldn't be completely dismissive of them.
Ah, the T56. Why try to drag race with a manual. Very few people do it well.
Dyno Tune. I'd probably punch whoever tuned that car for 11.0 AFR. That is pig rich for a N/A application. I wouldn't even run my nitrous tune that rich. 360rwhp is really low for the mods you have, and running a T56 as well. I'd recommend fixing that before doing anything else.
Shift points as well. Stop short shifting if you want a good ET.
As far as the Hooker Radials go, I've seen good things with them. I'd still recommend a full slick like an ET Street or Hoosier QTP for an M6 car.
You sir know nothing of drag racing. Please stop giving misinformed advice.
Have your car retuned/dynoed. Thats probably a BIG problem. Your car should put down close to 400whp with a T56.
If you have any vids of your runs post them up. Thatll help everyone to hear/see whats going on with your car.
Yeah, what they said. My A4 LT1 with bolt ons (and I'm missing some) and a mismatched 306 cam on stock heads, stock intake manifold and stock bottom end and only reving that cam to 6350 put out just about the same power with 110k miles on the engine. I would have expected you to be at about 390-400rwhp with a T56 and an LS1. I'd get it checked out.
AND I went 12.4 THREE times this Saturday on a bone stock suspension with Nittos on a mediocre prepped track when the DA was above 3000 and my trap was 3mph down from my previous best.
