how'd i/car do on this setup?
LQ4 with 317 heads with only a 3 angle valve-job so the compression ratio is still 9.4:1
Voodoo cam 232/238 .599”/.601” 112+3 LSA
SLP LT headers w/hallowed out cats and 3” all the way with no muffler
SLP Lid with free ram air mod
LS6 intake and ported TB
Stock 4L60 w/3200Stall
12 bolt 3.73 gears
16” v6 wheels 245/50/16 tire diameter is ~24.5”
OL tune with AFR 12.6 w/28* timing
Weight w/o driver 3475lb
i dont know if anyone (posted anyways on here) is running a similar setup that im running but if anyone's close to it im curious on their results. this is a baseline figure cause i plan on rebuilding the trans then go FI(dunno super or turbo yet).
gaining 3mph in DA alone. i know there's room for improvement and i imagine i can pick up a couple more mph if i work with the sixty footer as well as possibly going to a larger wheel diameter? also bare in mind im running 9.4:1CR as compared to 10.1:1CR fwiw. i believe the trans was shifting at 6100-6200 since i have the commanded shifts 1-2 at 5800 and 2-3 at 5850 Edit: the h/c are like 2.5 ls6's and like a 281 size cam. But I didn't pay attention to the compression drop that could be were its at. Are you planning for boost down the road?
12 sec section link
Here is a calculator to help do the math...
http://www.pszweb.com/car/gears.htm
just pick your car in the drop down menu, change the gears to 3.73, and put in whatever tire and rim size you want to run and hit calculate and it will bring up a graph and say what speed and rpm and gear.
