Worst track ever
Next time there watch a while and see if anyone is able to go around the water , doesn't sound right that they would make u go through the water with street tires.
Also realize the track is made to hook up , most crashes I have seen on street nights are cars with good power and on street tires that don't back out of the throttle when it's obvious that you just aren't going to hook up (still spinning at half track) then they finally catch traction and immediately go wherever they are pointed at the time of finding traction which is usually quickly into the guard rail/ wall , this is not the street so don't think because you can slide all over on the street you can do the same at the track.... When you hit dry prepped surface you will hook all at once....
My guess is you're running low 8s high 7s… High 80s, low 90s.
