new best first outing
Old Mar 1, 2014 | 09:28 PM
jblankenship's Avatar
Default new best first outing
Last year after my last outing I put some preload in the swaybar, adjusted pinion angle, swapped rear spring to stock cut ones, underdrive pulley, sealed up the ram air hood, and took a little more weight off the car. Results new best:
1.51 60'
11.41@119.xx
This was on 275/60s and a PTC nitrous converter and my home ported 241s. I was amazed. DA was -446(awesome)
Old Mar 1, 2014 | 10:05 PM
greenvortec97's Avatar
wow, identical times... with your 60ft being better than mine by a lot.. lol
Old Mar 6, 2014 | 03:10 AM
LS1rob00's Avatar
Congrats, those are some nice gains you had from doing that. It's all in the details!
Old Mar 9, 2014 | 07:42 PM
DA was +550 today and ran best:
1.556 60'
11.50x
120.25 mph
overall car ran:
11.59
11.57
11.53
11.50
Old Mar 11, 2014 | 02:52 AM
tyler ovel's Avatar
Dam congrats. Very consistent.
Old Mar 11, 2014 | 09:47 AM
thunderstruck507's Avatar
What did it run before?
Old Mar 12, 2014 | 05:30 PM
11.82@114 best 1.61 60', sorry it was in my sig when I posted this.
Working on a few other things as well to get everything out the car. Pulled about 8 lbs out the car today. Got a vibration in the rear when the car goes in third gear down the track and on the interstate at about 80 mph, same mph on track and interstate. Put it on jack stands and ran it in the garage. Thought I had a bent axle on both sides. Pulled both wheels off and ran it and no vibrations. Took the wheels to the shop we use at work and they spun the wheels on the balancer and the wheels have run out. The tires were out of balance too so they balanced them for me. I haven't been out on the roads yet or at the track so I'll update when I can.
Old Mar 13, 2014 | 04:00 AM
LS1rob00's Avatar
Nice, hopefully it's all good. Let me know if you need some more ideas for some weight to pull
Old Mar 17, 2014 | 09:11 PM
11SECSS's Avatar
Have you ever thought about trying a 90/90 combo it help my car and it was stock internals
Old Mar 18, 2014 | 09:27 PM
I would love too, but I'm trying not to spend much. I like playing with the nitrous. Thought about selling all the nitrous and concentrating on all motor but that's just not me. But it's something cool about going 10s all motor. I'm still full interior, radio, AC, and all that good stuff.
Old Apr 5, 2014 | 06:06 PM
update: New Best
Richmond Dragway last night
motor passes:
1601 Da
1.5765
7.3919
93.21
11.6524
114.75
980 DA
1.6094
7.3869
91.72
11.6360
116.70
Nitrous passes:
1x .047/26 @ 900psi, single NOS nozzle, NOS mini set to 0.5 delay,start 0, build 1.0,end 99
576 DA
1.5768
7.0450
99.25
11.0402
119.97
2 x .047/26 @ 800 psi, two NOS nozzles, NOS mini set to 1) 0 delay, 30 start, 1.0 build, end 99. 2) 1.0 delay, start 50, build 0.5, end 99.
576 DA
1.4712
6.6820
104.68
10.4758
127.44 Spinning on top end bad pat the 1000, 18 psi in the MTs
overall very pleased, fresh bottle with correct psi and 15 psi in the tires and a track like MIR or VMP and I think 10.20s possible.
Old Apr 5, 2014 | 09:56 PM
11SECSS's Avatar
Very nice .
Old Apr 6, 2014 | 04:54 PM
LS1rob00's Avatar
Nice, congrats on the new times.
The two motor passes go to show you how much of a difference DA makes.
Old Apr 14, 2014 | 07:35 PM
Just wanted to update those nitrous jets listed above were .047/.024 not .026
Old Apr 20, 2014 | 08:36 PM
Ran a 10.460 @ 130.xx this past friday on the same jets but with B8ef plugs and better mph. Pretty consistent. Did the same cutting in and out at the top end. Not spinning this time. I'm pretty sure it's my window switch set to low on the upper rpm. Adjusted and ready for next time out. I also picked up a NX 2 stage MAF setup to replace the two NOS nozzles so we'll see how it goes next time out. I have .044/.024 x 2 in the new set up. Will check the plugs.
Old May 5, 2014 | 09:35 PM
got the NX MAF installed. Will test it this friday.
Old May 17, 2014 | 01:00 PM
Finally got a clean pass on the NX MAF plate. I made a hit last week to the 1/8 on .044/.024 on both stages. First stage was set to 0 delay, 30% start, build to 1.0. Second stage turned on 100% at 1.0. Ran a lazy 6.76. I say lazy because it felt much smoother than my nozzles had. I did leave in the kids car seats and floor mats on this pass.
Last night I pulled out the floor mats, kids seats, and junk in the back like normal.
15 PSI cold in the MTs
18 degrees total timing
B8efs plugs at .030
First stage was .047/.024, 0 delay, 30% start, .6 build
Second stage was .053/.028, 100% on at .7
DA: 571
60: 1.4698
330: 4.2191
1/8: 6.5558
mph: 106.46
1/4: 10.2867
mph: 129.35
Pretty happy with this. It did cut out twice on the top end but no where near as bad, so I need to bump the window switch up a touch higher. Think I'm going to put .053/.028 in both stages and stop there. Car needs an anti roll bar bad. So that's where I'm going next.
Old May 18, 2014 | 09:28 AM
Beave's Avatar
What hp shot does that equate to? Still on the 10 bolt rear end? Solid run for sure.
Old May 18, 2014 | 12:40 PM
It's about 185. The two .053 should be just over 200. Yes still on the 10 bolt and 4l60e with an hd2 kit.
Old May 21, 2014 | 09:41 PM
BigBirdZ06's Avatar
Nice time
