headed to track friday. turbo c1500 what times can i look for?
1990 c1500 short wheel base. Truck weights 3800 lbs. I have an lq4 with 224/228 cam dual springs s480 turbo with 1.22 ratio. holley hi ram intake with 102tb. fic 1000cc injectors. holley dominator efi system. holley 1800 fuel pump with fuel cell in bed over tires. I have 3500 circle d converter with ford 9'' rear with 2.73 gears and spool. THis has 28'' et drag radials. I am intercooled and plan for around 14lbs. i will run this on the two step leaving at around 3k if i will hook. truck with cam and converter before weight savings ran 8.5 at 90. this time also was with it as a long bed and now its a shortbed.
