What do you guys think?
Old 08-24-2014 | 09:27 PM
02fbody35th's Avatar
Default What do you guys think?
I'm looking for some input on my 1/4 mile times? My mods are in my sig. But in short my combo put down 413/400 to the tire on a Dyno. Today at Numidia dragway the DA was 2500ft and I ran a best of 12.9 @111mph. I'm on street tires and my 60' time was 2.024 my car is full weight. And I'm about 200 lbs. I figure my race weight is probably around 3700 lbs. are my times inline with the power I'm making or no? Obviously with a better tire and quicker launch I should be faster. But how much do you guys think I'm leaving on the table here? Thanks for your input
Old 08-24-2014 | 09:30 PM
HCI2000SS's Avatar
Your trap is a little low. Have you ran before at other tracks?
Old 08-24-2014 | 10:10 PM
Well I ran at this track when I was cam only and ran a 13.2 at 109mph. I also ran at one other track cam only and I was 12.9 at 111mph. I know it's a slow track because of the higher DA. But I picked up 3 10ths and 2 mph after a head swap. I was expecting a little more being that the Dyno said I picked up 43 hp and 30 ftlbs. So where do you think I should be with my trap speed?
Old 08-27-2014 | 09:13 PM
murphinator's Avatar
DA and 60 foots are killing you. My stock internals bolt ons 174k full weight a4 went 12.1 @112 the only time I took it to the track( very negative DA) had a bad fuel pump , should run top 11's this fall. and I watched the previous owner of my stock internals bolt ons full weight M6 car go 11.9 @ 111 3 for 3 in its only track passes back when it only had 215k on it 242 k now ( I was there in one of my 4 door v6 SC w bodies due to low da's that night running low 12's). yes I am beating you over the head with DA lol its that important !
Get sticky tires and wait till the Da's are low and it will run much quicker for you , I never take any car to the track with bad da's or crappy tires you will always be disappointed ..
Your current trap says threshold of 11's with a good 60 foot and your da shows on a night with improved density your traps will improve - you have an 11 sec car to trap that well on a 2500 da night you just need to dot the i's and cross the t's , your car should trap close to 115 in negative da with proper cool downs.
Old 08-28-2014 | 07:40 AM
Thanks for this valuable information. I'm gonna hold off till the fall and take it back to the track and see how it runs.
Old 08-28-2014 | 06:46 PM
Your welcome , also pay close attention to guppymech's tire recommendation he is correct that a bias ply will work better with m6 it doesn't shock the drivetrain as hard and may save your 10 bolt to fight another day lol
Quick Reply: What do you guys think?
