9 sec RCSB
Old Jul 10, 2017 | 05:23 PM
subeone's Avatar
Default 9 sec RCSB
Customers juan razo RCSB 4500lb full weight ac daily driver
Engine is a gen 3 aluminum block (used a 5.3 block with 4.8 internals) 4.8 NNBS intake stock 706 heads chinese studs oem headgaskets KHP turbo kit s476 batmowheel bullseye turbo T4 with a 87mm turbine wheel
Has an ljms stage 2 cam, 7.4 pushrods, and btr double springs
Transmission is a 80e with internal dual feed mod and a 2b circle d converter
Rear is 10 bolt with moser axles detroit tru trac and 4.10 gears
Stock driveshaft, stock front shocks, stock rear shock location, VAS traction bars.
Tires are et street R and wheels are racestars, 30" tire and 17" wheel.
Fuel system is 2 450 lph walbros in tank, 8 an feed, aeromotive fpr, stock truck fuel rails, 210 lb injectors, e85.
No idea on horsepower nor torque, made 800whp/800wtq on 20 psi on a cast standard t4 s475, I am guessing it's close to 1000whp now.
This is on a 2 psi launch, footbrake, 24# tune up. Shifting it at 7200.
Attached Thumbnails 9 sec RCSB-19748758_1334889576630228_6302808108668195469_n.jpg   9 sec RCSB-19959029_1132216713545590_5812965712891407886_n.jpg
Old Jul 10, 2017 | 05:28 PM
subeone's Avatar
Old Jul 11, 2017 | 12:35 AM
007FJ's Avatar
Besides that hope and a prayer 10 bolt...That is a bad bitch.
Old Jul 11, 2017 | 09:18 AM
subeone's Avatar
haha yeah.. although, we havent seen many broken 10 bolts on our turbo trucks!
Old Jul 11, 2017 | 12:33 PM
LS1FREEK's Avatar
13 Second Truck Club
That's legit man, great setup!
Old Jul 11, 2017 | 02:18 PM
sillysspeed's Avatar
Nice! Thing is making some power
Old Jul 15, 2017 | 05:18 AM
DietCoke's Avatar
Truck 10 bolts aren't at all related to the 7.5 in the f bodies. they arent weak.
Old Jul 16, 2017 | 02:14 PM
subeone's Avatar
Thanks guys! We are going for a 30# glory run next week
Old Jul 17, 2017 | 05:50 PM
007FJ's Avatar
Default GM Rears
They are still crap. That's why the TBSS came with a 9.5 14 bolt. I am glad his is living of course. I had the 8.5" 10 Bolt in my GN. Still not the greatest at less torque and weight than subone. His setup is allowing it to live...so far so good.
