Question about M6 vs. auto ET times
Lol@1200 in a t400......guess you gonna run it with no converter.
A t56 faceplated with good internals is fine, mine doesn't even have viper shafts.
It's gonna take a good clutch no doubt. Ignition cut type shifting would never wouldn't lose boost. And you manhood would still be intact with a man pedal.
obviously I was talking about just the transmission. Even when you figure in the converter..... still cheaper. And I don't know this to be true, as I've never run a faceplated transmission..... but don't they wear out faster.... and make driving on the street a real chore?
I'll keep my t56 and muh doodads.
Sounds like you couldn't shift that fast before. Guys like you need autos i suppose
We can do all the styles of tracks. I bet i win more with my stick car. You're stuck with one.
Oh no.... don't get it twisted. I can shift as fast as anyone, was just always scared of killing the transmission.... hence no power shifting. The one time I got aggressive at the track....destroyed the worm gears. Guys like me.... that want to go fast....yes....automatic. And before you start the "can go as fast or faster with a stick" argument......you're dead wrong. There isn't a soul living that can out shift an automatic, and it remain intact. There's a reason the fast guys use 350s and the ever popular...tried and true 400.
Lol, I have faith in the manual that's for sure! But I'd give you the hit and keep mine on wastegate just to make it sorta fair!
#32
Ohhh hell...lol. Things have changed since the days of 11.30 @137.....its not the same car . But yea, you do that.... keep it on the gate and give me the hit..... would never see you. Same goes for liningup even, with you all in.
#33
But a ignition cut faceplated t56 would hang right there with a auto. I have no turbo just a bolt on ls6 so you likely out power me by alot but the stick is far mire versitile and fun to drive.
#34
I'll be happy with a 1.4 60 ft once I slap on the 28 inch slicks this fall.
1.52 spinning so far, stage 2 t56, monster 3, moser 12 bolt, tokico shocks. Nothing fancy but gets the job done for a car that sees the track a few times a year.
#37
^This. I never broke my 10 bolt even at 600rwhp. But as soon as I swapped to a 9" and tried leaving off the 2 step, I snapped the pinion yoke. Replaced it with a billet yoke and set the 2 step to 4k slipping the clutch=multiple 1.5 sixty foots at 3800lbs. Blue99fbody has now been, what 8.06 with his 6 speed? Just takes more time and setup to get it right.
#38
#39
While that car is indeed fast, it's not exactly a garden variety 6 speed either. Not sure what it weighs, but I've seen the car in person (hard to imagine it being heavy) ....and it's a completely stripped down racecar that gets pushed to the burnout box. We're talking street cars here.
ET @ MPH ------ 60ft ----- clutch ------ cubic inch - power adder - raceweight - username
8.06 @ 181.25 - 1.34 - Monster LT1-RR --- 376 -- CRT GT5588 ------------- 3200 - Blue99fbody
8.69 @ 156.00 - 1.26 - Mcleod soft loc ---- 402 --- N/A --------------------- 3195 - ls1 joe
8.77 @ 163.83 - 1.40 - Mantic triple ------- 376 --- F1X --------------------- ???? - jaredz28
8.78 @ 166.79 - 1.44 - Mcleod st twin ----- 325 --- Twin 6266 ------------- 3150 - ATSMATT
8.81 @ 155.05 - 1.30 - Mcleod Twin ------- 398 --- nitrous xxx shot ------- 3500 - Taner
8.85 @ 154.20 - 1.28 - Sof Loc ------------ 418 --- .082 Jet Plate ---------- 3160 - BES Stroked Nova
9.16 @ 152.19 - 1.38 - Mcleod RXT -------- 347 --- YSi --------------------- 3250 - 69ls6
9.18 @ 150.73 - 1.35 - Monster LT1R ------ 382 --- 88 Jet Puck ------------ 3250 - HSESWS6
9.24 @ 163.XX - 1.40 - Tilton 4 disc ------- 405 --- Precision 91mm ------- 3495 - Darin D
9.25 @ 154.46 - 1.46 - McLeod RXT ------- 325 --- S484 Turbo ------------- 3900 - gtistile
9.25 @ 152.90 - 1.48 - RPS Triple --------- 402 ---- N2O 250 shot --------- 3605 - Stonabones
9.33 @ 142.XX - 1.32 - Mcleod Single ----- 388 ---- N/A -------------------- 3180 - robz
9.35 @ 163.37 - 1.59 - McLeod 1200 twin - 376 --- PT4788 ----------------- 3050 - gnx7
9.35 @ 146.53 - 1.33 - Spec 3 ------------- 406 ---- Nitrous 250 shot ------ 3400 - 87__TA
9.57 @ 146.9X - 1.54 - RAM single iron --- 364ci -- S480 turbo ------------ 3510 -- 3pedals
9.59 @ 149.13 - 1.53 - ???? ---------------- 402 ---- supercharged --------- ???? -- LETHAL ZO6
9.59 @ 144.03 - 1.27 - Ace NexGen ------- 454ci --- NA -------------------- 3000 - SSSTANG
9.64 @ 141.78 - 1.40 - Monster Stage 4 -- 408 ---- N2O -------------------- 3516 - Slvrbackls1
9.64 @ 143.05 - 1.43 - Textralia Exo Skel - 403 --- N2O 150 shot --------- 3475 - James@ShorTuning
9.64 @ 140.39 - 1.34 - Boninfonte --------- 346 --- N/A Cam-only --------- ???? - robz
9.68 @ 144.36 - 1.45 - Mcleod RXT -------- 416 --- N2O 250 shot ---------- 3900 - ls2 bait
9.71 @ 141.97 - 1.40 - Mcleod RXT twin --- 404 --- N2O 200 shot --------- 3820 - BarneyMobile
9.71 @ 140.94 - 1.34 - McLeod RXT ------- 402 --- N2O 200 shot ----------- 3760 - GTA91
9.74 @ 145.39 - 1.42 - Textralia twin ------ 402 --- Twin turbo ------------ 3250 - highpockets
9.76 @ 151.XX - 1.59 - McLeod RXT ------- 427 ---- Twin turbo ------------ 3530 - R_trim 93GT
9.78 @ 150.52 - 1.51 - Spec twin disk ----- 402 --- supercharged --------- 3850 - speedracer5532
9.79 @ 140.74 - 1.44 - RPS twin disk ------ 440 --- N2O 0.030 pills ------- 3725 - GasTiresandOil
9.80 @ 142.00 - 1.35 - Ram 402/910 ------ 346 --- N2O 225 shot --------- 3650 -- smokeum99ta
9.85 @ 144.75 - 1.55 - ???? ---------------- 346 --- supercharged --------- ???? -- stevieturbo
9.87 @ 139.00 - 1.45 - Mcleod softloc ----- 441 --- N/A -------------------- 3200 - romanss
9.87 @ 138.70 - 1.38 - RPS BC2 ----------- 427 --- N/A Bolt-On Only ----- ???? - GARY2004Z06
9.88 @ 142.51 - 1.42 - Cartek ------------- 346 --- supercharged ---------- 3500 - SSmokin 01
9.91 @ 155.10 - 1.78 - Mcleod Meba ------ 404 --- Twin GTX35R Turbo --- 3400 - xLBx
9.92 @ 144.24 - 1.52 - Spec Stage 4 ------ 346 --- Turbo ------------------ 3750 - MIGHTYMOUSE
9.93 @ 136.XX - 1.41 - Spec 3i ------------ 347 --- N2O 200 shot ---------- 3800 - 02SOMWS6
9.94 @ 138.00 - 1.30 - Spec Stage 3+ ---- 364 --- N2O 200 shot ---------- 3450 - Quick Time
9.97 @ 135.55 - 1.36 - Monster LT1-S ---- 370 ---- N/A -------------------- 3030 - thirdgenbum
9.98 @ 140.25 - 1.41 - McLeod Twin ------ 346 --- supercharged ---------- ???? -- alwaysinboost
10.02 @ 136.00 - 1.55 - Tex OZ700 ------ 346 ---- N2O 150 shot --------- 3475 - Speedyws6
10.07 @ 135.60 - 1.48 - Mcleod Twin -----385 ---- N/A -------------------- 3250 - roadtrip120
10.09 @ 155.08 - 1.84 - Spec Twin ------- 418 ---- GT91 Turbo ----------- 34XX - 98silverbullet
10.12 @ 139.31 - 1.56 - monster 11in ---- 403 ---- N2O 100 shot --------- 3700 - dodson55
10.14 @ 136.00 - 1.40 - Spec Stage 3+ -- ??? ---- N2O 250 shot --------- 3465 - JeffT
10.15 @ 134.xx - 1.36 - McLeod RXT ----- 346 ---- N2O 150 shot --------- 3340 - 2 Stroke Racer
10.19 @ 137.74 - 1.45 - Spec Stage 3+ -- 395 ---- N2O 120 shot --------- 3585 - cdubbzz
10.24 @ 135.XX - 1.47 - McLeod RXT ----- 416 ---- NA --------------------- 3085 - 1mean96ss
10.32 @ 132.35 - 1.43 - Cartek ----------- 346 ---- N/A -------------------- 3300 - WS6TransAm01
10.33 @ 136.88 - 1.51 - RPS str twin lite -376 ---- N2O 125shot ---------- ???? - 1sickc6
10.33 @ 136.00 - 1.52 - Spec Stage 4+ -- 427 --- N/A --------------------- 3600 - Tweaked Zed
10.35 @ 136.48 - 1.9X - QM twin --- Stock 5.3 --- GT45 -------------------- 2950 - coltboostin
10.36 @ 132.00 - 1.45 - Mcloed Single --- 346 --- N2O 150 shot ----------- 3650 - Sprayed 99
10.37 @ 132.70 - 1.47 - Spec Stage 4---- 346 ---- N/A --------------------- 3400 - Torkman15
10.37 @ 131.00 - 1.38 - McLeod St Twin - 346 --- SBE LS1 150 shot ------- 3650 - ezzlez28
10.40 @ 131.15 - 1.41 - LS7 clutch ------- 346 ---- NA ---------------------- 3035 - ls2 dude
10.41 @ 132.9X - 1.48 - RXT clutch ------ 376 --- D1sc --------------------- 3950 - L92 fox
10.44 @ 128.80 - 1.48 - Tex oz700 ------- 402---- N2O 100 shot ----------- 3850- blu byu EH
10.45 @ 136.94 - 1.54 - Monster Level 3 - 427 --- N/A ---------------------- 3450 - Jeremy@RPMTransmisions
10.47 @ 132.91 - 1.54 - Textralia 0Z700 - 416 --- N/A ---------------------- 3250 - Jimbo's Z06
10.51 @ 129.00 - 1.52 - Mcleod Twin ----- 346 --- N2O 150 shot ----------- 3400 - TAGOES11S
10.51 @ 128.58 - 1.42 - ??? --------------- ??? ---- N2O 150 shot ----------- 3700 - Joey@TickPerf
10.52 @ 131.61 - 1.53 - Monster lvl 6 ---- 346 --- TC76 --------------------- 3550 - Tally TransAm
10.54 @ 134.69 - 1.56 - Mcleod RXT ------ 347 --- Comp 7479 -------------- 3720 – 1999Black_Z28
10.57 @ 131.77 - 1.49 - KYClutch --------- 364 --- N2O 150 shot ------------ 3700 -- James@ShorTuning
10.58 @ 134.09 - 1.68 - Spec Stage 3 ---- 357 ---- YSI ---------------------- 3700 - NUFNUFFZ28
10.63 @ 129.62 - 1.56 - Monster LT1-S --- LS7 ---- N/A --------------------- 3430 -- Mikey 97Z M6
10.64 @ 133.42 - 1.63 - RXT -------------- 346 --- 76GTS 11lbs ------------- 3750 -- Nitroused383
10.64 @ 129.99 - 1.54 - Textralia OZ700 - 346 ---- N/A --------------------- 3580 -- BriancWS6
10.65 @ 131.95 - 1.61 - Monster stage 3 - 347 --- N2O 150 shot ----------- 3540 --- High Impact
10.66 @ 128.24 - 1.44 - RAM HD ---------- 346 --- N/A cam only ----------- 3160-- studderin
10.67 @ 131.87 - 1.57 - McLeod RST ----- 383 ---- T76GTS @9psi ---------- 3800 -- ddnspider
10.68 @ 128.00 - ?.?? - stock-------------- 346 ---- N2O 150 shot ----------- Civic ??? -- Civette
10.71 @ 127.37 - 1.64 - Spec Stage 3+ -- 346 ---- Twin turbo -------------- 3700 -- Fitz98ta
10.76 @ 132.82 - 1.76 - Mantic 9000 ----- 364 ---- Rear 76mm 14psi ------ 3945 -- NJTurboZ28
10.76 @ 126.23 - 1.55 - ram twin --------- 346 --- N2O ---------------------- 4000 -- transampetews6
10.77 @ 134.4X - 1.77 - Mcleod RXT ------ 346 --- P1SC --------------------- 3380 - Fotoboy
10.78 @ 131.74 - 1.62 - RAM HD ---------- 346 --- N2O xxx shot ------------ 3520 -- ssfast99
10.78 @ 129.XX - 1.52 - Spec 4 ----------- 347 --- N2O 125 Shot ------------ 3300 - Gary Z
10.78 @ 127.45 - 1.54 - Mcleod Twin ----- 412 --- N2O xxx shot ------------- 3805 -- Rampant
10.79 @ 134.80 - 1.70 - Spec Stage 3 ---- 370 --- N2O 200 sho-------------- 3900 -- jmm98ls1
10.80 @ 126.XX - x.xx - Ram PG HD ------ 350 --- N2O 150 shot ------------ 3600 -- mtperformance
10.82 @ 126.90 - 1.47 - Textralia OZ700 - 346 --- N/A ----------------------- 3470 -- GrannySShifting
10.83 @ 138.07 - 1.80 - LT1R ------------- 408 --- S480 ---------------------- 3700 -- Necrocannibal
10.83 @ 134.00 - 1.80 - Textralia Z-grip -- 346 --- Procharger --------------- 3770 -- AFASTYZFR1
10.83 @ 128.07 - 1.54 - Monster LVL 4 --- 415 --- N/A ----------------------- 3400 - underdog
10.84 @ 127.80 - 1.57 - Spec Twin -------- 346 --- N/A ----------------------- 3190 - Demonicbird00
10.84 @ 126.80 - 1.52 - Monster LVL3 ---- 418 --- N/A ----------------------- 3700 - 82CETuner
10.86 @ 126.00 - 1.48 - 11 inch monster - 346 ---Cam only LS1 ------------- 3200 - zmg00camaross
10.89 @ 132.04 - 1.66 - Monster Level 3 - 402 --- 100 shot ------------------ 3430 - Hardcoresoldier
10.89 @ 131.8X - 1.80 - Spec 3 ------------ 364 -- N/A ------------------------ 2920 - Tweek
10.89 @ 128.30 - 1.60 - McLeod RXT ------ 402 --- NA ------------------------ 3760 - GTA91
10.98 @ 127.02 - 1.59 - Monster LT1R ----- 416 -- NA ------------------------- 3675 - stippy17
10.90 @ 130.90 - 1.76 - SPEC 3i ----------- 380 --- N/A ----------------------- 3750 - YellowB4Z
10.91 @ 128.18 - 1.56 - KYClutch ---------- 364 -- N2O 150 shot ------------- 3700 -- LSxPwrdZ
10.94 @ 126.90 - 1.53 - Mcleod stre twin - 346 --- N/A ----------------------- 3850 - big dave
10.95 @ 126.71 - 1.57 - Spec Stage 5 ----- 383 --- N/A ---------------------- 3600 - badpewter-z
10.95 @ 125.70 - 1.61 - Quarter Mstr 8.5 - ??? --- N/A RX-7 ----------------- 3000 - Project GatTagO
10.96 @ 124.00 - 1.76 - OZ 700 ----------- 408 --- supercharged ------------ 3700 - nvmy2000ss
10.98 @ 126.00 - 1.57 - CARTEK ---------- 346 --- N/A ----------------------- 3528 - SickSS228
#40
If anything I hoped you would swap out that little turbo. I know how that little turbo performs and it just doesn't make enough jams to hang. Once you get the rear sorted out and get a bigger turbo (or add another one) I can see the car going a good bit faster.
