Polluter V2 cam w/ PRC 243's 1/4 mile results
Work that 60' and you have your 10.XXX
play with the shift points too....mine seemed to like the lower shifts Vs the higher
7500- 11.3's
7000- 11.1's
65-68- 10.9X
didn't get to try 6000 yet...
7500- 11.3's
7000- 11.1's
65-68- 10.9X
I talked to my tuner about it and he said he does it all the time.
They may be weaker but think it may be blown out of proportion on the internet.
I really pounded on my car this season and it saw high rpms for long periods of time at a road course event so if it was going to let go, this summer would of been it lol
Ya, my speedo is off also only at wot. My tuner said don't pay any attention to the factory tach
Ya, I think so. Take care of the tranny hitting the rev limiter and will probably go to a yank PT4400.
Stuff like this makes me smile. Your SBE car from '98, runs harder than the blown modular mustang that I ran at the track last week. And as HCI 2000 said.... car sounds good man. Get that transmission dropped yet?
Thanks much
Not yet, just put it in a trailer today and brought it to where I store it for winters. Maybe in January/ February I will start on the transmission when I get bored.
Break time from working on that damn thing lol
I wouldn't bother with trying to eek out a 10.90. Your car is clearly making some good power, and with the right changes, you could be running 10.50's. You're giving up at least .2 in the 60' alone! 1.59 60' needs some work. I'd throw a pair of QA1's or Vikings up front to get some weight transfer going on. A little weight reduction wouldn't hurt either. You're so close to running some awesome numbers! Have you thought about restalling to a PT4400? Or maybe going with an SS4000? It's going to be all the little changes you make at this point that will get you to your goal. Definitely run some better headers. Your car is the first one I've seen run an impressive number with Pacesetters. If you're trailering your car to the track, lose the rest of the exhaust behind the headers, that's just restriction and weight. What are you running for an induction setup?
Exhaust needs some work. I have the PS headers running into ory the I cut the merger off and welded a cutout in right there. Different headers are on the to do list for sure.
I need to rebuild my transmission this winter so I will be having the converter re stalled to a PT 4400. My shift extensions right now are at about 6000 rpms, Just a bit more extension will help out a lot a think along with a better 60'.
Induction before the 102 tb needs some attention eventually.
Stock maf sensor so that is a bit of a bottle neck.
Underneath my air filter I do have that plate cutout so it's able to get some air.
Maybe a tubular k member in the future also.
#32
Nice....likely better than a lid.
Here's mines
There is lots of weight reduction you can do w/o hurting the drivability of your car. You could drop 30lb off the front just goin to a lithium battery. Get you a ewp and set it up with out a tensioner really free's up the motor and unclutters the front of it while reducing weight. Panhard brace can go away as a bunch of bracketry on the rear.
Personally for a auto car i would likely leave the suspension stock until it started acting ill. You seen to be getting some decent 60s as it is.
Here's mines
#33
Here's mines
Here's mines
Tranny needs rebuilt and I'm restalling the converter. I would like to see around 6300+ shift extensions which I think will help with my setup a lot. I'm really aiming for 125 mph trap next season so we will see.
I do plan on riding the stock suspension out as long as I can.
#35
Ya, there are definitely a lot of little things I need to change. I'm on stock suspension right now besides relocating the stock torque arm off the tail shaft.
#39
