1st time track evaluate
Went out to Joliet Rt. 66 last night for final test and tune. 2002 Z/28 t-56 long tubes ory 3" catless to single Magnaflow to the bumper. Didn't care too much about the times but the car was going through the lights at 107 plus on the limiter in 3rd. Ran it 3 times all very close. I think this was on par with what the car could do stock when it was new? If so, why would someone replace the factory manifolds and emissions equipment for zero gains? Stock wheels and 3.42's.
THANKS
Chuck
work on your launch and look for a better tire, you can apply the power sooner with traction (more time at WOT, less time pedaling)
I've seen cases where improving 60' lowered mph but NH's slips don't look that way (yet).
Our stock tuned, lid, drag radial 02 WS6, 6 spd. at over 3,665 lbs race weight ran many 107 mph+ passes with 1.95 to 1.99 60 foot times in the 13.07 to 13.13 range. It also pulled off 12.75 at almost 110 on a 1.80 60 foot time in good air and backed that run up same day with a low 12.90 with a slower 60 foot time.
If the 60 foot times where like yours coming off the line easy they would have been 103 to 104 mph passes easy.
Also on the limiter in third kills MPH go ahead and shift into 4th and you willl see a difference.
Hope this helps.
N2
Haha that's exactly how I drove the car that night. Out of the gate at idle.
Next rip, I will try and bring it out a bit harder.
One thing I also noted was that after just cleaning the tires off prior to staging the idle was kind of hanging up at 1500 for a brief moment. I assume they all do it? Seemed wierd that it didn't drop immediately after pushing the clutch in.
The "launch" part of the run only lasts the first 10-15 ft out of 1320 ft, that's why it doesn't hurt MPH. However, deviations at the top end can change the MPH drastically, ie: letting off, or stretching out a gear farther than it should. I agree that you need to hit 4th gear, that should help MPH.
Al
