Almost in the 5's
Old Jan 30, 2019 | 08:21 PM
Jtm2085's Avatar
Default Almost in the 5's
First track outing of the year. The DA was a -100 and I almost met my goal for the current combo, which is a 5.99 pass. The first pass was on motor and it was a PB 6.91 at 100mph and 10.83. The car was spinning on the nitrous passes, but the best was a 6.08 at 114, let off at the 1/8 coasted to a 10.15 1/4. The 1/4 traps were off all day. They laid some fresh prep on the track and I tried one last time to break into the 5's. The car dead hooked, pulled the tires and then the rear end broke. Ls6, tfs220's, btr 4 cam, nitrous outlet plate kit and th400
​https://youtu.be/6Z97JepDD0M
https://youtu.be/GtI2WoU__6o
Old Jan 31, 2019 | 07:47 AM
sxc Z28's Avatar
Nice pass! What rear were you running?
Old Jan 31, 2019 | 09:07 AM
Jtm2085's Avatar
Thanks! It is a moser 9in, with 31 spline axles and the a trac lock. I haven't pulled it apart yet, but I'm willing to bet the trac lock **** the bed. Time for a light weight spool
Old Jan 31, 2019 | 07:32 PM
Doug G's Avatar
Damn, congrats on the PB
What size shot ?
Old Jan 31, 2019 | 10:03 PM
Jtm2085's Avatar
Thanks Doug, I was running a 250 shot. I really wanted a 5.99, but I guess I will have to be content
Old Feb 2, 2019 | 07:54 AM
Doug G's Avatar
Sucks when **** breaks, throw in some 35's and a spool....one place a little over-kill wont hurt.
That's the plan I took, cost was the same 31/33/35.
Old Feb 2, 2019 | 08:25 AM
Jtm2085's Avatar
Yep, that's the plan if I have a broke axle. If it's just the shitty trac lok I will just replace it with a spool for now. I still need a few more things to be ready to race for the year lol
Old Feb 3, 2019 | 09:06 PM
Jamie R.'s Avatar
Congrats man that's getting it done !
Jamie R
2kTa
Old Feb 3, 2019 | 09:21 PM
Jtm2085's Avatar
Jamie R
2kTa
thank you Jamie. Pulled the axles out, they look good. Looks like it's time for a spool
Old Feb 5, 2019 | 05:38 PM
z28241's Avatar
Jt +1 on the Spool, i just went to a Spool myself
Old Feb 9, 2019 | 07:21 PM
assasinator's Avatar
Originally Posted by Jtm2085
First track outing of the year. The DA was a -100 and I almost met my goal for the current combo...The first pass was on motor and it was a PB 6.91 at 100mph and 10.83. The car dead hooked, pulled the tires and then the rear end broke. Ls6, tfs220's, btr 4 cam, nitrous outlet plate kit and th400
you realize josh, that your car has a ls6 block, TFS heads, a decently large cam, high stall converter, a SD tune, and on motor you make 500rwhp. honest to god 500rwhp....all of those things. and you are slower than someone else's silver SS with stock 243s, stock cam, stock ls6, and street tires.
you achievements are exactly the way a car like your should and will perform. but you are 1 tenth slower and a bunch of MPH slower than that other Silver SS in spite of all of your work making you car a FANTASTIC drag car.
just sayin. your car is incredible man. but slower and not as good of a performer as a stock LS6.
Old Feb 10, 2019 | 04:46 PM
Jtm2085's Avatar
Lol, I feel like it runs pretty well for what it is. The converter obviously isn't set up for NA, and that hurts it for sure. I really need to weigh it again. I'm sure it's a few hundred lbs heavier than the car your talking about. I wish the trap would have been working on that run. I would guess it was 126-127. Pulled the 3rd member out, shattered the spider gears lol.
