Bolt on ls1 eighth mile
ls6 intake
full exhaust
ptc 4000 converter
lid/k&n
had some good weather. Bout 100-300 DA
got the 275 et street radials on and was happy to hook up and get some nice times
I’m pondering doing the FRA mod and maybe a ported TB and bypass. Obviously wouldn’t add much but ever little bit helps especially if I’m so close to that 7.6x pass already
pondering a rear gear change. What kind of real world track improvement am I looking at with 3.73’s or maybe 4.10?
it has a 3.23 now. I would think that they would help sixty foot pretty good. I just run 1/8 mile.
eventually I’ll do a cam swap and later down the road a 100-150 shot.
Fast 102 with ram air. You would need it for when you cam it anyway.
Weight reduction. There us weight all over these cars. It just crap you'll never miss and it can clean the car up and make it easier to work on.
Drag pak
Ati balancer
Crank scraper
Electric water pump.
E85
Gear 3.73 or 3.90
Shocks....the stock decarbons arent that good.
As others has said remove the front bar. You could make some links to preload the rear bar a little if you like tinkering to help the launch.
Carbon ds
Dyno tune, maybe you have one but you didn't list it.
Sxc car runs great. No reason you can pick up .5. Then hit the stock cam with a 100-150 and really make people scratch their head when you run well into the 6's in the 1/8 with a stock cam.
Drag pak
Ati balancer
Crank scraper
E85
Gear 3.73 or 3.90
Carbon ds
sxc car does run great. Looked at his thread and saw his track times.
im interested in doing skinnies up front as well as a rear gear change. What is your gear of choice for what I have in mind for the car?
the 3.90 looks like a good compromise between the 3.73 and 4.10
i looked at a mph/gear calculator and 3.90 would give me plenty of room to grow without being too crazy on the interstate.
On top of that the 4.10/4.11 gear set is weaker than 3.73/3.90. Pretty important with a 7.5 to consider that.
I’m not against the ram air for any reason other than my trans cooler is too big to fit it and I spent too much time and effort getting it mounted to change it lol
hope to run at the track Thursday, weather permitting, and see how it runs in warmer weather
