Bolt on ls1 eighth mile
Old Jun 16, 2020 | 10:42 PM
nmass399's Avatar
What is your exhaust setup? Getting rid of the maf and running an sd tune could possibly help a little.
Old Jun 17, 2020 | 11:17 AM
mrbigjeep's Avatar
It’s speed engineering long tubes and o/r y pipe with a slp magnamouth catback
Old Jun 17, 2020 | 07:35 PM
nmass399's Avatar
Ok, that should not restrict you much if any.
Old Feb 26, 2022 | 08:11 PM
mrbigjeep's Avatar
i was a little disappointed, i added the ported throttle body, under drive crank pulley, and the ram air hood and it made absolutely zero difference. I know none of those individually will make for much difference but i thought combined would at least make a small difference. Ran a couple months ago in some great weather and it ran a 7.75 and that was with a better 1.59 sixty foot..
oh well, i'm still happy with 7.7 for a full weight bolt on car.
I'm ready to do an aftermarket cam now.
Old Feb 27, 2022 | 06:43 PM
Z28SteveA4's Avatar
Ram airs depending which one is usually good for 1-3 mph. What was the da this time to the track compared to the last time you ran a 7.7x?
Old Feb 27, 2022 | 06:44 PM
Magnet's Avatar
agreed. DA is very important to make sure your comparing apples to apples.
Old Feb 27, 2022 | 08:16 PM
mrbigjeep's Avatar
Right, for sure.
they were extremely similar, it was around 100ft the most recent run and the original 7.7 was also 100-200 ft
although the original time was at a different track. I haven’t been able to run there again since then.
