NEW STOCK INTERNAL RECORD!!! 10's?!?!? Maybe!!!
Old 08-23-2004 | 02:36 PM
  #41
Pro Stock John's Avatar
LS1Tech Co-Founder
12 bolt is another 30 lbs but it's not apples to apples, the gear swap would make a big difference in torque multiplication.
Keith still have a the V6 rear sway bar on there, so it's not as strong a a V8 one from the factory.
I disagree on the tire height issue. Since his car is so light the power to weight ratio is different. He could maybe go lower 1.4's, I think that Silver98Z28 (Rich A) runs 26x10.0's and might have gone a low 1.4 a few times.
Old 08-23-2004 | 04:10 PM
  #42
8seclt1's Avatar
Originally Posted by bad2000ss
I see that you have 3.42's currently. Hopefully changing to the 4.11 gears will negate the power loss of the 12-bolt. If you were going 4.11 10-bolt to 4.11 12-bolt it would deffinately hurt you.
My car is deffinately slower compared to other cars with similar weight and mods than mine other than a 12-bolt and a heavier driveshaft. Took me a while to figure out why this was, but the heavier drivetrain components deffinately slowed me down.
If I were you, being so damn close to 10's, I would leave everything the way it was and wait for some good air. In this case concerning the 10-bolt, if it ain't broke, why fix it.
the air was KILLER already... 38% humidity, 75 degrees, 30.00 baro, 1800-1850 corrected altitude.. couldnt ask for anything more..
Old 08-23-2004 | 04:49 PM
  #43
bad2000ss's Avatar
I would sure like to know what part of the country I need to go to get some of these -DA numbers that some people report. I don't think i've ever seen better than a 1200' DA out here.
Old 08-23-2004 | 05:16 PM
  #44
8seclt1's Avatar
cordova is 632 above sea level... air was at 1150-1200 most of the day.. add those together to get corrected altitude..
Old 08-23-2004 | 05:28 PM
  #45
SilverGhost's Avatar
Motorboater
we'll get a negative DA once in a blue moon around here.
Ask 01-Z, he seems to catch it every damn time.
Old 08-23-2004 | 06:05 PM
  #46
LS1Tech Co-Founder
-DA like on November 30th... When we go to US41 with hot chocolate and mittens to take advantage of the Houston-like air.
Old 08-23-2004 | 06:39 PM
  #47
Villain281H's Avatar
7 Second Club
From: Gainesville, Florida # of drag strips runs: ?!?!?
congrats, daymn that's movin
Derek
Old 08-23-2004 | 09:03 PM
  #48
Squintz Palladoris's Avatar
Keith, How much do you weigh if you don't mind me asking. I am a skinny little bastard weighing in at a whoppin 120lbs. Put me in the drivers seat and tell me how to launch it!
Brad
Old 08-23-2004 | 09:12 PM
  #49
ChevyWeatherman's Avatar
master of the "jack"stand
Originally Posted by Magnus
here is your excellent quality of the record run!!
magnus_11-029.wmv
Thanks!!!
Awesome!! My pleasure!
Old 08-23-2004 | 09:23 PM
  #50
SMOKIN01TA's Avatar
Originally Posted by ONEBADWS6
Time for a drag bar to level those launches
i was just thinking that same thing,might help plant that launch a lil better
damn kieth, thats movin out man, congrats.
Old 08-24-2004 | 10:31 AM
  #51
Silvr98z28's Avatar
Congrats.....that is kickin ***. Hope you decide to bring it to Thunder and at least run brackets.
To answer PSJ's question, yes I'm running a 26x10 tire and have gone best of 1.41 at 3320lbs. I've been down on power lately because I found out I'm floating valves. Heads are being freshened up and getting a forged short block as well.
Old 08-24-2004 | 03:28 PM
  #52
LINGENFELTER SS's Avatar
ARE everything im guessing huh Rich? Looks like ur ready to get this bitch running a little faster. Congrats
Old 08-24-2004 | 10:23 PM
  #53
Magnus's Avatar
LS1TECH Sponsor
Thanks everyone!
The weight of the 12 bolt is a concern of mine. I am thinking I will just do it anyway along with bogarts all around and front runners as well. I'll take the die grinder to the car some more this week to clearance the wheel wheels for the next set of tires and such. Perhaps the weight will add up.
So the concensus is 3.42/10 bolt to 4.10/12 bolt on the same tire will not result in a quicker ET for a stock internal NA stripper car?
You guys worry me cause I'm not sure if my tires will last another round at the track.. and my next set has to be 28x10's, not 28x9's.
Old 08-25-2004 | 02:41 AM
  #54
Magnus's Avatar
LS1TECH Sponsor
Old 08-25-2004 | 10:22 AM
  #55
RUQWIKR's Avatar
Just saw the thread! Awesome! What's the raceweight these days? Take care and get in the 10's! Take care. Dave
Old 08-25-2004 | 12:01 PM
  #56
LS1Tech Co-Founder
If you were keep running 28x9's and went to a 12 bolt with 4.10's you would pick up for sure!!!! If you could hook it. Your car lugs in 3rd gear right now (since the converter is pretty loose) and I think that is what is causing the low traps. Either that or the tranny is slipping but I don't think so. True the 4.10 would help with the converter as well, your converter is pretty loose.
Old 08-25-2004 | 12:13 PM
  #57
bad2000ss's Avatar
I was going to ask earlier if the car was losing a bit on the top end. The 1/8 mile ET and MPH is deffinately good for 10.90's at 123ish.
The 28X9's would deffinately fit a lot better than the 28X10's. If you start spinning the 28X10's fast enough they will expand and rub on the rear fender well. I was running a used set of 28X9's (almost to the wear marker) and they hooked REALLY well. I believe the diameter of the 28X9's is actually 27.3".
Good luck with whatever you decide to do.
Old 08-25-2004 | 02:25 PM
  #58
LS1Tech Co-Founder
I think he's driving through the converter on the big end, but that's just my opinion.
Quick Reply: NEW STOCK INTERNAL RECORD!!! 10's?!?!? Maybe!!!
