Good...Bad? Your input....
Here are my bests:
r/t: .020
60': 1.75
1/8 et: 7.88
1/8 mph: 87.65
1/4 et: 12.34
1/4 mph: 110.66
The car now traps 110 consistently....110.41, 110.47, 110.66, 110.52.
Suspension Mods: V6 springs, bmr lca brackets.
Engine Mods: TR224, LS6 Intake, Jet Hot headers/ORY, lid/filter.
Trans Mods: MW3500 2.0, cooler, TransGo shift kit, deep pan.
Other than that, the raceweight with me is 3680. I run 17.5-18 psi cold in the Nitto DRs....17" ZR1s all the way around....car is untuned.
So, does this look good or bad? I am thinking my next step is the BMR relocated torque arm tied into SLP subframe connectors. QA1s out back...relocated battery.
Opinions.....
other than that, get the car tuned and get the shift points up to where they need to be and you might have a good runner for you weight.
The other thing I forgot to mention is the shift points. I have a Diablo Programmer which I bought to compensate for the gears. I have raised the limiter to 6600, and when I had the shift points at 63-6400, it would just bump the limiter. So when I get it tuned, I want the shifts at 64-6600 and the limiter at ~6800 (with new springs and hardened pushrods). Right now it shifts at 6150...booo, I know...
Thanks for the replies so far.
Derek
You know....for things like your cam swap
