Is this 60 ft. typical for an M6?
Old Nov 4, 2004 | 06:05 PM
dwhiteZ28's Avatar
Default Is this 60 ft. typical for an M6?
The best 60 ft I was able to get with my SS was 2.406 on Eagle F1 streets . l launched at around 2200 RPM, rolling out the clutch but she spinned in first thru second. Is this typical? What can I expect with DR's and how will this affect my e.t.? Thanks..BTW, altitude was 4,300 ft.
Old Nov 4, 2004 | 06:32 PM
MIGHTYMOUSE's Avatar
a 2.4 is typical of someone just burning the tires down the track yea try leaving softer
um go practice . i would be dissapointed with worse than a 2.1 on the factory tires when i run my drag radials i am happy to see a 1.8
Old Nov 4, 2004 | 07:01 PM
obrien24's Avatar
I get high 1.8s to low 1.9s on sumitomo street tires. I leave at the line between 3000 and 3500 revs
Old Nov 4, 2004 | 07:02 PM
SilverGhost's Avatar
Motorboater
2.4..I think I would be ok with that on ice maybe. Even on street tire if you know your car and can drive you should see nothing worse than a 2.1..aim to avg a 2.0 on a half way decent track.
drag radial you should sub 2.0 easy given above statement of driving and decent track prep.
Old Nov 4, 2004 | 10:00 PM
Turo's Avatar
well, the good news is that since that 60 ft is pretty bad, you should see a nice gain in e.t. as soon as you learn to launch better. personally, i cant launch any higher than ~1500 rpm's without spinning like crazy, so i say try launching at a little lower rpm (or slip the clutch).
Old Nov 4, 2004 | 10:28 PM
gator's 99TA's Avatar
your track, BMP, is a hard hooking track remember. so is sunshine.
Old Nov 4, 2004 | 10:54 PM
dwhiteZ28's Avatar
Forgot to mention the 60 ft. time of 2.406 was at 4,300 ft. altitude. That might be part of the reason.
Old Nov 4, 2004 | 11:39 PM
GT Griller's Avatar
damn i thought my 60' times were bad. I get 2.3's and its an A4 but i got the 3.73's on shitty street tires.
Old Nov 4, 2004 | 11:51 PM
LEO's Avatar
LEO
I usually cut 2.0's on street tires, Nitto DR 1.7-1.8's.
