LS? What?? LT1's rule
LS1Tech Co-Founder
Hey Rick, do you have any videos from the front view of your car at the top end of the track? The reason I'm asking is because we were sitting near the finish line at the Thunder event, and at the top end of the track your entire nose bumper cover is caved in like a ****. It looks BAD, like you just had a collision with someone. I've seen this happen on quite a few 150+ cars, so you might want to add some internal bracing to that nose piece. Could be giving up alot of mph with a crushed front end like that.
Awesome numbers! Out of curiosity what was the issue with the old turbo? Did the bearings take a dump? Impellar dig into the volute? You mentioned cleaning out the intercooler so I assume there were shavings and/or oil in there?
#34
Originally Posted by y2khawk
About as streetable as mine i'd bet
Do i need to strap mine on the dynojet? Go make a pass already
#37
Rick, you are absolutely caving in the front nose if you ddont have any support in the frotn with bumper supports etc removed. Joes car flattened out trapping 135-140 last year early this year until he fabbed something up fo rit, actually ripped the frotn bumper at a crease I beleive. Youll pick up some mph too if you cna keep its shape. take about 1 or 2 pounds of aluminum to keep it all together
