Track Results (FINALLY) AFR 205 Project Car
Originally Posted by Magic Chicken
6 words Flip: At least my truck is running!
Originally Posted by CAT3
Tony, what was your MPH before the AFR Street Heads? Nice run, little soft on the launch but of course any harder and it would have been on the trailer earlier!
Tony M.
Originally Posted by maddboost
Tony did you break the differential case? Have you looked at DTEs rear end and trans brace?
When I get back from PRI next week I will take the car apart and see exactly what failed. I will keep you guys posted.
Regards,
Tony
#35
congrats!
You might want to consider lifting straight up off the clutch as fast as you can vs sidestepping it. It'll make parts live a lot longer and you'll sixty the same or better.
#37
LS1Tech Co-Founder
Nice results Tony, 110 for baseline mph is very much average.
It would be interesting to see what a set of those heads would do on a strong drag setup like 01-Z's, maybe a contender for fastest stock cube car on pump gas.
#40
I've seen H/C vette run 10.5x's many times with mph 130+.
To answer an earlier question, vettes break output shafts, gears, tranny, clutch often during serious drag racing.
