6.0 CARB'D cam only IROC hauling the mail!
i have 4300 in motor and go fast goodies all said and done.
i sold my old motor for 2600 then sold all the other supporting stuff with it, so i dont have a huge amount of money in it. 1500~
the box is the edelbrock, tho it is built by MSD.
the MSD box was supposed to come out in may.... but they set it back to next year!
its going to have all kinds of timing curves for boost, nitrous retards and window switches built in.... etc.
ill be getting one if it ever comes out.
thanks for the pics dan.
Outlaw 10.5 Director
![](https://ls1tech.com/forums/images/ranks/ls1tech20year.png)
If it is not comming out until next year, how did you get one?
Tom
SSU Moderator
I think he means the box FROM MSD won't be out till next year. You can get the same box (kinda...less options, little pills to adjust) from Edelbrock when you buy an intake.
the box i have comes in the edelbrock kit(built by MSD)
#33
Originally Posted by SilverSurfer
Did you have to make any chassis mods to get the LS6 exhaust manifolds to work? Nice set-up by the way.
i run a PA k member, and had to tap in the brace across the spring perch to clear one of the exhaust flange corners. its REALLY tight right there. i have to remove the studs to the the exhaust pipe out. its stuck otherwise.
RIGHT ON the rear a arm bracket.
it works tho, just a lil patience.
